Date/Time: Sun, 24 Nov 2024 03:49:47 +0000
Back Testing Speed
View Count: 1450
[2013-09-26 14:36:09] |
Richard Reyes - Posts: 98 |
I am running an i7 960 (3.20ghz) processor with 24mb of memory and a 256 SSD all on a ASRock X58 Extreme motherboard . I am back testing my FOREX automated trading systems (4 to 7 formulas) everyday and I am literally going to sleep waiting for them to process 100%. Is there something that I can do to my Sierra Charts to speed up the processing time or can you recommend a desktop computer system that will speed up my back testing or something else that I can do. Many Thanks
[2013-09-26 16:30:45] |
Is this a Spreadsheet trading system?
[2013-09-26 17:11:25] |
Yes it is.
[2013-09-26 17:50:37] |
Therefore, refer to this section for instructions to significantly improve back testing speed: https://www.sierrachart.com/index.php?l=doc/doc_Backtesting.php#ImprovingPerformanceSpreadsheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
