Date/Time: Sat, 18 Jan 2025 10:03:23 +0000
Zigzag reversal
View Count: 1261
[2018-02-10 16:22:40] |
User743212 - Posts: 5 |
Does anyone know how to change the zigzag amount reversal from percent or points to "TICKS"???
[2018-02-12 17:45:19] |
This is not supported with the study. Here are the description of the Inputs: Zig Zag: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
