Date/Time: Sat, 18 Jan 2025 10:17:12 +0000
Unmatched fills in trades tab
View Count: 929
[2018-02-10 10:18:07] |
nikos - Posts: 23 |
Hi, All orders have been placed through Sierra . the trade activity tab reports all orders correctly but the trades tab has unmatched fillls. Also, when I place the order from the chart trade, I can see the position line and the fill marker on the screen for a couple of seconds, then it disappears. Please advise, Thanks |
Private File Private File Attachment Deleted. |
[2018-02-12 17:42:11] |
In regards to unmatched fills, refer to: https://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#TradesTabUnmatchedFill (You really do not need to read this because it is not really the main issue) I can see the position line and the fill marker on the screen for a couple of seconds, then it disappears. This is why you have the unmatched fills.This problem is described here: Interactive Brokers Trading Service: Trade Position Line or Quantity Disappearing or Displaying Zero Either there is no position data for that symbol available from Trader Workstation or there is a problem that Interactive Brokers is aware of that they are resolving (At least according to another user). For now use the Order Fill Calculated Trade Position which is documented here: Trading Information Windows: Using Order Fill Calculated Trade Positions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-12 17:42:48
