Date/Time: Sat, 18 Jan 2025 10:59:21 +0000
zigzag not working properly
View Count: 804
[2018-02-09 23:41:46]
mwnl - Posts: 29
Hi there,
I have the zigzag indicator on my chart and it is not detecting the correct rotations. I have highlighted the errors on the chart and also attached the settings. Please can you help my identify the cause of the error.
imagezigzag error.png / V - Attached On 2018-02-09 23:40:54 UTC - Size: 266.59 KB - 276 views
imagezigzag settings.png / V - Attached On 2018-02-09 23:41:07 UTC - Size: 363.19 KB - 248 views
[2018-02-10 00:22:23]
You need to set the Input Data For Low Input to "Low".
