Date/Time: Sun, 24 Nov 2024 06:58:02 +0000
[User Discussion] - Quick alerts
View Count: 1824
[2013-09-26 12:31:51] |
mogull - Posts: 40 |
I am wondering if there is a way to set up something for a quick price alert. Like I am waiting for a move/price break so I put a horizontal line there (Configured for an alert) and when the price hits it, you get the alert. Or some simple way to do that? Thanks |
[2013-09-26 12:55:36] |
RMF2 - Posts: 43 |
The line drawing tool has this capability. If you draw a horizontal line and right click the line, a menu pops up with "Alerts" option. Selecting "Alerts" opens a settings window where you can set the details of the alert. |
[2013-09-26 13:12:31] |
When I right clicked on the hoz line and picked "alerts" nothing happened. I think I might have thos little balls on the line. No window. |
[2013-09-26 14:29:02] |
RMF2 - Posts: 43 |
The "Chart Drawing Alerts" window should pop up. The drawing alerts feature is described on this page: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#Alerts |
[2013-09-26 22:23:51] |
Nothing pops up. I promise. |
[2013-09-26 22:27:02] |
You will need Sierra Chart package 3 or 5 for Chart Drawing alerts. Also, you could use a Quote Board and set price alerts that way: http://www.sierrachart.com/index.php?l=doc/doc_GettingQuotes.html Alerts are not documented yet but they are easily set from the Alerts menu on the Quote Board. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-26 22:58:32] |
I have package 1 so I guess I'm out of luck. |
[2013-09-27 04:58:18] |
If you want to use Chart Drawing Alerts, that functionality is not available in package 1, but the Quote Board does support Alerts and also Simple Alerts can be used as well: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-27 04:58:37
[2013-09-28 01:58:20] |
I am wondering if there is a way with this method to have a different alert for if two lines cross one way or another. Like a MACD crossover you may have =CROSSOVER(SG1, SG2) And an alert. Is there a way to delineate which way the crossover is happening? Cross up or cross down? Or just a cross is a cross? |
[2013-09-30 09:32:38] |
Yes. Refer to the crossover functions here: http://www.sierrachart.com/index.php?l=doc/doc_WorksheetFunctions.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-02 01:44:18] |
I don't see anything directional
[2013-10-02 02:11:10] |
Sawtooth - Posts: 4118 |
Use the CROSSFROMBELOW and CROSSFROMABOVE functions to delineate direction.
[2013-10-02 11:29:47] |
But that has to be used in the worksheet, not the simple alerts, right cause you can only put one thing in there anyway, and that function works in the worksheet? just checking before I do all the work. (This is always a relearning process for "earthlings" like me.) |
