Date/Time: Sat, 18 Jan 2025 10:21:16 +0000
ACSIL System
View Count: 702
[2018-02-09 20:37:06]
User39772 - Posts: 311
I need to maintain data between the function calls of a trading system because in a next call I need this data that has been updated in the previous call.
I know that global variables could be used for that. Is there another way, e.g. to store such data in one of the structs that contain data for an open position.
I only need this data as long as the position is open.
Another question is regarding /BEtrailing stop. The existing examples are somehow confusing for me.
Implementing simple trailing stop and profit target in ACSIL | Post: 107946
TRAILING STOP ORDER USING ACSIL
It is not clear if I have to configure something outside of the ACSIL code additionally, e.g. in the trade window.
It would be helpful to have an ACSIL example that shows how to buyentry via a MKT and use a BE and trailing stop.
It is also not cleat what to do in the buyexit section in such a case.
A full example would be very helpful !
[2018-02-12 18:47:25]
You need to use a persistent variable. Refer to:
sc.GetPersistentInt()
For move to break even stops in ACSIL, refer to:
Automated Trading From an Advanced Custom Study: [Type: integer] s_SCNewOrder::MoveToBreakEven.Type
There is no buy exit needed. That is managed by the Stop Attached Order.
Date Time Of Last Edit: 2018-02-12 18:47:40
