Date/Time: Thu, 03 Apr 2025 19:32:25 +0000
Display position of multiple accounts on chart.
View Count: 1061
[2018-02-09 16:39:45]
User198817 - Posts: 56
I'm currently trading with two different accounts on the same symbol on the same exchange(XBT on Bitmex). Using the Trade DOM I can easily switch between the two accounts, and it displays the positions/orders perfectly. I have also setup the candle-stick chart to show positions/orders.
Currently the chart draws the price-line for my orders/positions for account #1 - not for account #2.
How can I change which account the chart gets the position/order data from? Is it possible to draw for both accounts at the same time?
Date Time Of Last Edit: 2018-02-09 16:41:05
[2018-02-09 18:21:35]
This is done through the Trade Window for the chart:
Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM)
No most definitely not.
Date Time Of Last Edit: 2018-02-09 18:21:42
[2018-02-09 18:26:24]
Thank you.
[2022-12-27 22:49:00]
mbarbhaya - Posts: 37
Dear Support, please help me with the information .. How to Display P/L of multiple accounts on one chart ? Is their any custom study or any setting in Sierra Charts, like we have this feature in NinjaTrader8.
[2022-12-28 14:55:11]
John - SC Support - Posts: 39147
If you are trading the multiple accounts from a single instance of Sierra Chart by selecting the different accounts on the Trade Window, then when you go to the Trade Activity Log, be sure to select "All Accounts" from the filtering options at the top and then you will be able to see the information for all your accounts. Refer to the information here:
Trade Activity Log: Trade Account Filter
If you are using different installations of Sierra Chart to trade the different accounts, then the only way to share the information between those installations would be to export the Trade Activity Log information from one installation and import it into the other. Refer to the following:
Trade Activity Log: Importing and Exporting Data
[2022-12-28 21:57:23]
Hi John, Is their an alternate way , instead of using Trade Activity Log. Some way by-which we see P/L of multiple accounts on single Chart Screen where we had enabled "Order Allocation to Trade Accounts"
