Date/Time: Tue, 21 Jan 2025 00:44:29 +0000
vertical scrollbar or vertical scroll keyboard shortcut
View Count: 2956
[2018-02-09 15:37:36]
whats1thingnow - Posts: 407
hi, is there a keyboard shortcut i can assign so that i scroll vertically?
right now i've been vertical scrolling with the hand tool, or ctrl+click on the vertical scale... but it takes many clicks to scroll on my TPO chart vertically.
i don't want to change the vertical scale of my chart because the range using "user defined" is set exactly to my preference.
a vertical scrollbar would be awesome too!
thanks!
[2018-02-09 18:22:15]
No. But here is the relevant documentation for this:
Chart Scale and Scale Adjusting: Interactive Scale Move - Move Scale Up and Down
You just need to use Interactive Scale Move.
[2018-02-09 20:21:13]
thank you - i already use ctrl+click on the vertical scale.
follow-up questions:
1) any chance a vertical scrollbar will be added in the future?
2) when i vertical scroll with hand or ctrl+click (interactive scale move), sometimes it simply stops scrolling.
for example: since i have many days loaded, i know there are TPO profiles below the current bottom price, but i can no longer scroll down
how do i fix this?
[2018-02-15 05:06:32]
hi, please let me know about the above post?
[2018-02-20 04:09:05]
sorry to bother you... still having trouble with this.
can anyone help?
[2018-02-20 06:03:41]
At this point we see no reason to be nice. You have 78 posts and then on top of that you are begging for features and help you do not even want to pay for and then on top of that you are asking for a trial extension. This is beyond reason.
Support is available at 150 USD per hour. We are declining further support.
Do not post further until you make a payment! This is getting completely ridiculous.
It is important to have respect for our time because it is detrimental for everyone when it is being taken away unnecessarily.
Date Time Of Last Edit: 2018-02-22 04:58:05
[2018-02-20 06:48:37]
Disregard the prior response. It has been hidden. But you are consuming too much support and we cannot do a trial extension.
We need to allow a greater interactive scale move range and that will be supported in the next release.
Date Time Of Last Edit: 2018-02-20 19:48:23
[2018-02-20 18:26:51]
We have increased the Interactive Scale Move allowed offset by three times. Update to prerelease 1705 following these instructions here:
If that still is not enough, let us know.
Date Time Of Last Edit: 2018-02-20 18:26:59
[2018-07-22 03:00:59]
sorry to bother you again with this, but scrolling the TPO chart vertically is really painful...
i've been vertical scrolling with the hand tool, or ctrl+click on the vertical scale even after the update... but it takes many 'click + drag' to scroll on my TPO chart vertically...
i don't want to change the vertical scale of my chart because the range using "user defined" is set exactly to my preference - the scale is set so that i can read the numbers on the dom chart properly
any chance for
1) vertical scrollbar
or
2) vertical page scroll keyboard shortcut
thank you very much!
SC is the best!!!!!!!!!!!!!!!
