Date/Time: Sat, 18 Jan 2025 11:11:15 +0000
User Question
View Count: 700
[2018-02-09 15:36:44] |
Sierra Chart - Max - Posts: 5779 |
Pouvez vous me dire svp ds le petit tableau des Trades
dans la quantité exemple 5 lorsque je perds 10 Pips a 5 = -50 le decompte est de - 100 Pourquoi ???? Merci du retour Can you please tell me about the little table of Trades
in the example quantity 5 when I lose 10 Pips at 5 = -50 the count is - 100 Why ???? Thank you for responding Sierra Chart Support |
[2018-02-09 18:23:41] |
Refer to this page for complete documentation about this: Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
