Date/Time: Sun, 24 Nov 2024 03:24:25 +0000
1028: Time Line study
View Count: 1444
[2013-09-26 09:18:59]
tobi - Posts: 351
Why did you change the look of the Line Style "Dot" in the Time Line study?
If this doesn't have a specific reason, could you please change back to the old look.
imageold-look.png / V - Attached On 2013-09-26 09:18:33 UTC - Size: 7.85 KB - 495 views
imagenew-look.png / V - Attached On 2013-09-26 09:18:37 UTC - Size: 6.45 KB - 481 views
[2013-09-27 02:11:59]
User22396 - Posts: 191
i prefer the old look as well
[2013-09-27 04:46:10]
We cannot control this. This is the result of using a different Draw Style. You will notice that we use Bar Top and Bar Bottom to ensure that the line is always visible as the vertical scaling is compressed.
[2013-09-27 12:15:49]
the old version was just like a vertical session grid line...was visually less intrusive...the problem with the new version is you cannot get it to look like a 'chart settings>advanced settings 2> vertical grid line'
maybe you can restore the old version under a different name? or allow different formats?
