Date/Time: Sat, 18 Jan 2025 11:11:34 +0000
What is the proper format to use to refer to fractions in Color Bar/Background Based On?
View Count: 719
[2018-02-09 11:35:46]
infpz - Posts: 826
For example, ID1.SG1 > 115 20/32?
I have tried a few different ways including 115'20 - can't seem to figure it out. Converting the fractional to a decimal works but I would rather not.
[2018-02-09 18:06:11]
We would have to check but there is probably no support to interpret a fraction like this.
You would need to specify it as a decimal number. We will have to see how to support a fraction. But it would require some sort of special delimiters to identify it.
[2018-02-09 18:41:06]
Sawtooth - Posts: 4154
This works:
ID1.SG1 > 115+20/32
[2018-02-09 19:22:15]
Actually yes, that would be a straightforward way of doing it.
