Date/Time: Sat, 18 Jan 2025 10:01:12 +0000
Hiding Zigzag study does not hide text labels
View Count: 687
[2018-02-09 09:01:24] |
phaedonk - Posts: 352 |
Hiding Zigzag study does not hide text labels (Length, time duration etc.) Also, I think these labels (at least duration, I could not find) do not show on the spreadsheet study. Do I need to calculate them myself? Thanks. |
[2018-02-09 23:35:08] |
Hiding Zigzag study does not hide text labels (Length, time duration etc.) You must be running an older version. This would be the only explanation for this. We do see one of the copies of Sierra Chart you are running is a significantly older version.There is no Subgraph for the zig zag line duration. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-09 23:35:27
[2018-02-12 11:54:23] |
I am running 1699. I have hidden all studies, still the labels will not hide. I am attaching a pic.
Private File |
[2018-02-12 12:14:48] |
Ok, it appears that after a chart reloading/recalculation the labels do hide. It would be helpful if that was not needed.
[2018-02-12 16:11:44] |
We do not observe this. The labels immediately hide when the study is hidden. It could have something to do with the method by which you are hiding the study. That actually must be it and that is not going to change because you are probably hiding the studies using an efficient method directly from the Analysis menu. We are not going to force a full recalculation in that case. This is just how it is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-12 16:12:34
