Date/Time: Sat, 18 Jan 2025 10:12:16 +0000
Is there a way to drag multiple orders at the same time ?
View Count: 1775
[2018-02-09 07:10:05] |
Acro - Posts: 441 |
Hi, If I have initiated say three separate one contract trades and I have manually moved each OCO stop order to the same price, then is there a way to drag all of those three stop orders at the same price to a new level ? At the moment, I need to drag each individual stop order. I have tried using the shift, control, alt and combinations thereof to no effect. This would be a great stress and time saver when in the heat of a live trade. I know that Rithmic Trader and Multicharts have this ability |
[2018-02-09 10:01:07] |
Yes. There is a way to do this and we need to prepare documentation for this. There are menu commands for this in Global Settings >> Customize Chart Trade Menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-09 10:01:28
[2018-02-12 21:36:20] |
John - SC Support - Posts: 37327 |
The documentation for these items can be found here: Chart Trading and the Chart DOM: Moving Orders Using the Chart Trading Shortcut Menu For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
