Date/Time: Mon, 14 Sep 2026 13:20:15 +0000
NYMEX Futures Spreads...
View Count: 1735
[2018-02-09 01:42:30]
User629089 - Posts: 93
I'm interested in the futures spreads that are available in SC's through NYMEX, specifically the Brent WTI spread and if possible the Crack spread. The Crack spread is subtracting 3 WTI crude from 2 barrels of gas (RB) and 1 distillate (HO) I believe. The last spread available under "Find Symbol, Futures Spreads - NYMEX (SC Exchange Data)" is the only Crack spread I see which is for Brent instead of WTI and doesn't appear to include HO, just RB only. Is that correct? The Brent WTI spread is above on the list and likely what I'm looking for. Also, just above the WTI-Brent Financial Futures - NYMEX listing, is Brent Crude Oil Futures - NYMEX. Brent above under the Futures contracts is listing ICE as the exchange in London which is correct. What is the Brent Crude Oil Futures - NYMEX contract?
Anyway, I found the procedure for setting up the platform for this data which I think looks easy enough. I'm wondering, is there an add'l fee for the SC data? Is there anything else I'm missing?
Thanks a lot...
[2018-02-09 18:40:25]
It is best, that you activate the Sierra Chart Exchange Data Feed and can actually list of the available spreads. Refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ExchangeTradedSpreads
If there is a particular spread that you want which is not listed, then let us know which specific one and we will make sure it is listed. All of the exchange traded spreads should already be available.
Yes.
We do not understand the question. If there is a particular futures contract you want from the CME and it is not listed, just give us a link to the CME specifications for it.
