Date/Time: Sat, 18 Jan 2025 07:52:06 +0000
All orders are cancelled directly after entry
View Count: 597
[2018-02-08 17:12:27] |
pkhst958 - Posts: 57 |
SC used to work fine for me for the las months. Now I have a strange issue. All my stop buy/sell orders are cancelled directly after entry. How can I fix that? I have uploaded a backup which shows the same problem.
[2018-02-08 22:02:39] |
Refer to the instructions here: Trade Activity Log Analysis: Support Assisted Trade Activity Log Analysis You need to determine why it is the orders are getting canceled. It is first best to contact your Trading service about this and find out. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
