Date/Time: Sun, 24 Nov 2024 04:10:33 +0000
Plotting Point of Control Moving Average.
View Count: 1638
[2013-09-26 02:45:06] |
User46635 - Posts: 3 |
I would like to be able to create a prototype where I calculate and plot Moving Average of Point of Control, X bars. Bars can be any periodicity. Currently, using 6 tick range bar on Gold for the prototype. |
[2013-09-27 05:17:16] |
Calculate the point of control and then put the results into a sc.Subgraph[].Data array or one of the additional arrays on a Subgraph and then calculate a moving average using that as input data: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Functions.html#scSimpleMovAvg Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-27 05:17:44
