Date/Time: Sat, 18 Jan 2025 10:43:48 +0000
[Programming Help] - Triangular Bollinger Band Custom Study Issue
View Count: 635
[2018-02-08 15:17:53] |
User540789 - Posts: 2 |
TBB file attached. Reeived the following error when attempting to build: TBB.cpp: In function 'void scsf_TBB(SCStudyInterfaceRef)': TBB.cpp:67:123: error: expected '}' at end of input BollingerLowerBand[sc.Index] = BollingerMiddleBand[sc.Index] - (StdTemp[sc.Index]*BollingerStandardDeviations.GetFloat()); Suggestions? |
TBB.cpp - Attached On 2018-02-08 15:16:37 UTC - Size: 2.32 KB - 394 views Attachment Deleted. |
[2018-02-08 22:19:46] |
You are missing a closing curly brace } at the end of the file to close the function.
