Date/Time: Sat, 18 Jan 2025 10:50:43 +0000
tradeing system based on alert condition
View Count: 1683
[2018-02-08 13:48:50]
User835963 - Posts: 18
hello guys,
could you please post the supporting document for 'trading system based on alert condition'.
I don't can't get it to work and I'm not sure what am I doing wrong.
thanks.
regards,
[2018-02-08 22:35:05]
The documentation for the Trading System Based on Alert Condition will be ready by Monday. We apologize for the delay, but it just takes time to get everything done.
[2018-02-12 15:08:18]
John - SC Support - Posts: 37327
The documentation for this study is available now. It can be found here:
[2018-02-12 17:24:47]
Let us know if you have any further questions.
[2018-02-13 15:06:16]
You guys are the best, I have never come across a group of dedicated individuals like you guys...
just for the record I will have you know I used to be a proud owner of Ninjatrader-still'am- but I'm no longer proud nor do I touch it anymore since I made the conversion to SC.
by the way, I wrote a dumb request on my other account name AC 109743, please disregard it everything is working beautifully.
one more question is there a way or maybe an order type will allow me to enter an order below or above current market? meaning buy bid minus 4 ticks for example...if not I'm just so happy with what I got.
[2018-02-13 18:47:50]
We also added step-by-step instructions for the new Trading System Based on Alert Condition study:
Did you want to do this with automated trading? If not, refer to:
Basic Trading and the Trade Window: Custom Trading Keyboard Shortcuts
[2018-02-13 21:25:46]
Yes, sir ..you nailed it right on the head.
If I could, I would like to set it up in the attached trading window as an order type where your beautiful new study or even spreadsheet system for trading could use it as an order entry method...if I'm not mistaking, I believe this method called RBO entry method
"Reversal Breakout Order", its technically an order entry method to take advantage of the immediate temporary price pullback caused by the vacuum of bid/ask volume above or below the current market..of course, you knew that, did not need my too long of an explanation :-)
the idea is to have it set up in the trade window so users can use it to hit into the market on the chart DOM, trade DOM, utilize it in trading system based on alert condition study or even on a spreadsheet system for trading without having to hard code on lines J22-J25 or J72-J75 if they wish.
thank you very much for your hard work.
sincerely.
[2018-02-14 05:24:13]
Yes this does make sense. The Attached Orders configuration on the Trade Window will be used by the Trading System Based on Alert Condition study. This is explained here:
Trading System Based on Alert Condition: Step-by-Step Instructions (step 13)
[2018-02-14 16:36:20]
hello,
so is this something you will be interested to look into, I mean the RBO?
and another thing, did anybody report the indicator evaluating before the bar closed while the settings Evaluate on Bar close set to Yes?; or maybe is something wrong with my alert formula??!!...I have a 10 tick range bar and 2 instances of the indicator with the same formula reversed one for buy entry and the other for sell entry and I let the attached trade strategy take care of the exit,however I would be in a long trade and immediately after the close of this trade (very small target) another trade in the opposite direction is open without waiting to evaluate on the close of the bar...this could happened several times thru out the same bar formation!!
also regarding Depth of Market Data study how do I do calculations on the provided levels of depth beyond level one, say I want the sum of the best 4 bids and the best 4 asks?...
sorry I have been asking a lot of questions of you guys...lol
thanks.
Regards.
Date Time Of Last Edit: 2018-02-14 19:35:34
[2018-02-15 03:19:48]
This certainly can be the case. And it is not inconsistent with how Evaluate on Bar Close is implemented. Refer to the updated description here about this:
Trading System Based on Alert Condition: Inputs
Date Time Of Last Edit: 2018-02-15 03:21:15
[2018-02-15 03:22:15]
This data can be accessed through this study:
