Date/Time: Sat, 18 Jan 2025 11:12:08 +0000
max in trouble
View Count: 851
[2018-02-08 09:29:20]
User988578 - Posts: 24
HI my sierra chart keeps freezing has a blue circle so i cant move or open different charts . noticed this over 2 or 3 days but it no longer corrects any suggestions please
[2018-02-08 10:06:36]
The first thing to do is to not use the existing Chartbooks. Refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook
Then the next step is to just start with new charts:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.17 - Rebuilding Your Chartbook
And when you have time try to figure out the problem with the existing Chartbook by going through the other items on this page:
Date Time Of Last Edit: 2018-02-08 18:17:04
[2018-02-09 16:33:13]
i still cant access my charts David dube says there may be some issue with sierra chart and ptg software but i have not changed my version of sc. i cant open the log as everything says not responding.
turning off with windows task manager does not help
i have a screen shot but that wont upload here
maybe i can email it but in essence nothing responds!
so i need more help please
imagenot responding.JPG / V - Attached On 2018-02-09 16:32:12 UTC - Size: 200.75 KB - 293 views
[2018-02-09 18:18:05]
OK the very first thing you need to do is to run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
If you still have a problem with your existing Chartbooks, then start a new Chartbook.
We cannot help with the custom studies but we can prevent them from causing a problem. This is why you need to use Safe Mode.
