Date/Time: Sat, 18 Jan 2025 07:54:44 +0000
just buy limit sell stop?
View Count: 648
[2018-02-08 08:12:01] |
User378082 - Posts: 33 |
when the price is above my order ,can I set to let the trade menu just buy limit & sell stop?
360截图20180208161028615.jpg / V - Attached On 2018-02-08 08:10:53 UTC - Size: 183.05 KB - 292 views |
[2018-02-08 12:42:53] |
Xfanman1 - Posts: 320 |
Do you mean if price is above your order you want only the Buy Limit and Sell Stop options to show on the submenu, similar to what happens in NinjaTrader? To the best of my knowledge you can't do that in SC. I do have my chart submenu setup (similar to yours it looks like) with a separator between upper order types for when price is below my desired entry and then the lower menu options for when price is above my desired entry. This way I don't have to "think" about which type of order I need when trades are moving quickly. |
ChartTradeMenu.PNG / V - Attached On 2018-02-08 12:42:11 UTC - Size: 25.87 KB - 270 views |
[2018-02-08 14:13:13] |
Sawtooth - Posts: 4154 |
You can do this if you are using the ChartDOM, and you use the settings shown in the attached pic.
ChartDOM settings.png / V - Attached On 2018-02-08 14:10:35 UTC - Size: 20.76 KB - 252 views |
[2018-02-08 15:00:14] |
There is this option: Global Trade Settings Windows: Reject Chart Trade Orders That Will Immediately Fill (Global Settings >> Chart Trade Settings >> General >> Order Entry) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
