Date/Time: Sat, 18 Jan 2025 07:52:19 +0000
Another User sending charts
View Count: 622
[2018-02-08 07:42:07] |
User773516 - Posts: 1 |
Another User has sent me a chart. Although I can download the charts. Once opened all is blank. How can I view the data within.
[2018-02-08 08:33:20] |
You need to make sure the symbols of the charts match the particular Service being used. Refer to this section here about this: Data/Trading Service Connection and Symbol Issues: 1.3. Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
