Date/Time: Sat, 18 Jan 2025 10:48:40 +0000
Limit on symbols
View Count: 996
[2018-02-08 04:47:34]
User713273 - Posts: 409
I have subscribed to 500 symbols. I was alerted as I was entering that my limit is 200.
[2018-02-08 05:09:02]
We see you have activated 3 real-time connections. Do you need these 3? Or do you need just simply the one?
[2018-02-08 05:24:20]
Just one.
[2018-02-08 09:01:05]
Has the symbol requirements been reset to 500? thx
[2018-02-08 15:07:55]
Yes.
Reconnect:
[2018-02-08 15:08:08]
Sierra Chart - Max - Posts: 5779
We have cancelled the 2nd and 3rd real-time connections for your account. The remaining connection is set to 500 symbols.
Sierra Chart Support
[2018-02-08 22:05:41]
Can I get access to an additional 500 symbols plus access to one additional connection? If so, what are the cost associated with this?
[2018-02-08 22:40:20]
Yes but you do have to activate that additional connection and pay for it.
Pricing can be found here:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#DataConnections
Date Time Of Last Edit: 2018-02-08 22:40:34
[2018-02-09 01:07:16]
I'm unfortunately continue to get the symbol error relating to I've reached my max limit of 500 symbols even though I'm currently using under that said threshold.
[2018-02-09 04:44:11]
Provide a copy of the Message Log by following these instructions:
[2018-02-14 06:22:37]
I have enabled a 2nd data feed connection, I want to enable another 300 symbols how would I go about doing this?
Please advise.
Date Time Of Last Edit: 2018-02-14 08:18:42
imageUntitled.jpg / V - Attached On 2018-02-14 08:00:01 UTC - Size: 207.01 KB - 304 views
[2018-02-14 18:45:37]
We do see the second real-time connection activated and it is authorized for 500 symbols:
It must have the same number of symbols as the first connection. It cannot be less.
Date Time Of Last Edit: 2018-02-14 18:45:44
[2018-02-14 21:40:47]
Ok great, didn't think I had yet activated the 500 symbols on the 2nd data connection.
