Date/Time: Sat, 18 Jan 2025 11:07:37 +0000
trading chart DOM question - can vol be added?
View Count: 1441
[2018-02-07 21:54:15]
User7817001 - Posts: 96
is it possible to show volume bars in the chart dom?
the dom has volume bars, i would like to get the chart dom to include volume bars too
this will allow me to eliminate the dom
to be clear, i do not want the bid/ask volume on the dom
please see attached
#1 is where I wish to see the volume bars
#2 is the dom volume bars what i want to show up on the chart dom
thank you
Mark
imageCapture.JPG / V - Attached On 2018-02-07 21:53:42 UTC - Size: 175.84 KB - 475 views
[2018-02-08 22:45:16]
Yes of course. Just add the Volume by Price study to the chart:
https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#StepByStepInstructions
Date Time Of Last Edit: 2018-02-08 22:45:27
[2018-02-09 10:14:03]
Thank you for the quick and concise reply.
Following the recommendation placed the VbP lines on the chart, based on the chart.
I wish to have the bars to right, outside the chart proper.
I wish to have the bars associated to the Chart DOM, to the right of the chart proper, where the Chart DOM is located.
I wish to have the Chart DOM (to the right of the chart proper) include the trade volume bars, as does the DOM proper.
Please see attached.
I understand if this is not possible.
Thank you again,
Mark
imageCapture.JPG / V - Attached On 2018-02-09 10:13:58 UTC - Size: 118.18 KB - 383 views
[2018-02-09 12:11:27]
Xfanman1 - Posts: 320
SC Engineering support may have another solution for you but the best I've been able to do is shown in the images below. You can get close to what you're asking by setting the VbP settings to right align and you'll have to reduce the length to something smaller so it doesn't overlay your entire chart (I'm using 10 in this example). Adjust the Tick Size to get a wider bar encompassing more than one tick if you want. Using the 1 tick setting will give you a volume bar for each tick but it will be very small on your chart compared to the DOM.
Scott
imageVBP.PNG / V - Attached On 2018-02-09 12:10:30 UTC - Size: 230.79 KB - 386 views
imageVbP Settings.PNG / V - Attached On 2018-02-09 12:10:54 UTC - Size: 90.58 KB - 346 views
[2018-02-09 18:58:45]
Here is the documentation to do this:
Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart
[2018-02-11 09:57:22]
Thank you all for the recommendations.
I will try them.
Mark
