Date/Time: Sat, 18 Jan 2025 08:02:21 +0000
Enabled "Support Scale In" + "Support Scale Out" doesn't save?
View Count: 1037
[2018-02-07 16:52:22] |
tesseract353 - Posts: 66 |
If one or both scaling options are enabled with "Simple Bracket" selected in the Trade Window, selecting "2TargetsWithBEStop" causes the enabled functionality to disable. Is there a way to save a user's selection? Or does this functionality need to be re-enabled, if desired, every time we change a preset order configuration? |
[2018-02-07 18:38:58] |
After changing those settings you need to save the Trade Window configuration again: Basic Trading and the Trade Window: Saving Trade Window Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
