Date/Time: Sun, 24 Nov 2024 05:47:28 +0000
trade activtiy log window eror
View Count: 4184
[2013-09-28 02:17:07] |
You will not be able to change the trade account until you can connect to the trading server and most likely the trading server is down over the weekend.
[2013-09-28 16:00:19] |
User89634 - Posts: 40 |
ok ,,tumarow i try
[2013-09-28 21:47:40] |
We have solved the problem where you are not able to select among the specified TT FIX accounts when not connected to the FIX server. Update Sierra Chart to the latest revision selecting Help >> Download Prerelease and let us know if you can select any of the accounts after the update. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-28 21:48:10
[2013-09-29 20:46:01] |
again update ? 1029 i have
[2013-09-30 09:18:51] |
not good again .I placed a limit order YM and no shows it on the chart, and the option is turned on, it is not executed
no order ym.PNG / V - Attached On 2013-09-30 09:18:43 UTC - Size: 56.26 KB - 422 views |
[2013-09-30 09:27:13] |
now all the instruments ok bill, only Russell is 25000, but do not execute out the orders of other instruments
russell ok order.PNG / V - Attached On 2013-09-30 09:27:06 UTC - Size: 52.75 KB - 408 views |
[2013-09-30 09:30:08] |
Go to the chart and select Trade >> Open Trade Window for Chart. Set the Trade Account on the Main tab to your account. Here are the instructions: http://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#SelectingTradeAccount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-30 12:05:32] |
ok all the instruments I specifically changed the account in the main window .. just russell is 25,000, I'll try it again today trade, I hope that it will finally ok,
