Date/Time: Sat, 18 Jan 2025 08:04:28 +0000
Issues with M6E Renko 2 tick chart
View Count: 659
[2018-02-07 16:26:11] |
User951413 - Posts: 13 |
I use a 2 tick Renko chart everyday, for some reason its plotting a (1)long bar since about 3:00 am. I've tried different things including updating my version, opening a new charts, etc. It plots a 1 tick and 3 tick, etc., just fine. Please advice. Thank you, Tom Trevino |
[2018-02-07 18:03:27] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image For now make sure that Chart >> Chart Settings >> New Bar at Session Start is enabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-08 15:25:44] |
We have this resolved. A release will be out in day.
