Date/Time: Sat, 18 Jan 2025 07:54:14 +0000
Zig Zag
View Count: 769
[2018-02-07 14:16:13] |
User99934 - Posts: 227 |
Ln:36 is not working
[2018-02-07 19:05:23] |
Most likely you have the Input setting for Volume to Accumulate set to None. Change this to some other value, and you will then have a number other than 0 showing for the Display ZigZag Volume/Length in Ticks. You can find the documentation on the ZigZag study here: Zig Zag Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
