Date/Time: Sat, 18 Jan 2025 07:43:29 +0000
[Programming Help] - Twitter message doesn't match time opening trades
View Count: 761
[2018-02-07 12:28:54] |
Autotrade8 - Posts: 26 |
Dear support, I want to start up a Twitter subscription service for automatically receiving signals. The signals which I receive now in Twitter are not correct in terms of time as well as the opening price of the position. The time is always displayed from the opening price of the Bar on which the signal is given. The trade opens next Bar because I have to use Signals only on Bar close in the Spread Sheet System for Trading study. Suppose I work with a 5-minute Bar then there is a time in the Twitter message 5 minutes too early. If I use 1 hour Bars then there is a time in the Twitter message of 1 hour too early. I work with Renko, so you understand the time can even have more difference. It would be awesome if the signals in the tweet matched exactly with the real actual opening time and price level of the position itself. That would be possible when looking at the trade activity log! Is it possible that something can be made made for this? I would be very grateful. |
[2018-02-07 18:37:40] |
No. You will have to create your own custom trading system using ACSIL to create your own custom messages: Advanced Custom Study Interface and Language (ACSIL) Automated Trading From an Advanced Custom Study Or you could just use the ACSIL to create your own custom alert messages: sc.AddAlertLine() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-07 18:37:58
