Date/Time: Sat, 18 Jan 2025 08:01:58 +0000
TWCONFIG file not working since update
View Count: 718
[2018-02-06 18:53:09]
superdoug3 - Posts: 40
my TWCONFIG file (see attached) should submit
Target 1 for 8 ticks
Target 2 for 16 ticks
STOP for 12 ticks
instead I get
Target 1 for 4 ticks
Target 2 for 8 ticks
STOP for 8 ticks with BE - 2 ticks
attachmentES3HV - Volatile - Scalp 2 keep 1 runner BE-2 stop.twconfig - Attached On 2018-02-06 18:52:08 UTC - Size: 6.18 KB - 403 views
[2018-02-06 19:49:26]
more information
1. attached are 2 TWCONFIG files
2. I usually use ES3 - this is working fine for me
3. when I switch to ES3HV, it appears to be still using ES3 i.e. Target1, Target2 and STOP still remain at 4,8, 16 and are not changed to 8, 16, 12 they should be
attachmentES3 - Scalp 2 keep 1 runner BE-2 stop.twconfig - Attached On 2018-02-06 19:48:45 UTC - Size: 6.18 KB - 403 views
attachmentES3HV - Volatile - Scalp 2 keep 1 runner BE-2 stop.twconfig - Attached On 2018-02-06 19:49:03 UTC - Size: 6.18 KB - 417 views
[2018-02-06 20:12:31]
The problem you are having is explained here:
https://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SettingsNotApplying
You are using the wrong Trade Window.
We do not need any further information. And we did test your first configuration file and it worked exactly as programmed.
