Date/Time: Mon, 03 Feb 2025 07:01:04 +0000
Is there a place like Charthub.com where one can download SC charts?
View Count: 1800
[2018-02-06 15:54:03] |
sjk - Posts: 43 |
Charthub seems to be all IRT charts.
[2018-02-07 01:16:13] |
What Sierra Chart has available is documented here: Sierra Chart Image Upload Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-07 05:05:47] |
sjk - Posts: 43 |
So the answer to my question is NO. Thank you, I guess.
[2018-02-07 05:13:05] |
sjk - Posts: 43 |
You really ought to think about promoting something like charthub.com for SC. People who are technically challenged or just want to spend their time trading instead of building charts are very likely to consider SC if it was easier to see what it can do and it was easier to use.
[2018-02-07 18:26:54] |
When you spend one or two days with Sierra Chart, you will see that it is not difficult and actually quite straightforward to use. Every task that can be performed with Sierra Chart has step-by-step instructions. These steps can be found in our documentation: https://www.sierrachart.com/index.php?page=doc/Contents.php Sierra Chart also has the capability to send Chartbooks which have been made by any user to any other user. Refer to: File Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-02 17:00:11] |
Joseph Helminiak - Posts: 21 |
I am coming over from IRT and was looking for the same. Trying to get SC setup like I had my IRT is a bigger challenge than I thought. I did receive a "chartbook" from some other users but I think some of the code is slow. My IRT was quick and SC seems to be lagging a bit. Coming from 32-bit to 64-bit I would think SC is able to keep up and should be leaner than IRT I also think something like charthub would have more users jumping on, so they can see you can build the same without the high cost of "other" platforms Date Time Of Last Edit: 2019-11-02 17:04:23
[2019-11-02 17:06:54] |
Sierra Chart is an extremely fast program. If you have any performance issues refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Make sure the symbols of the charts are correct. Refer to: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-03 02:33:04] |
We also see you are using IQ Feed. You need to use one of the Sierra Chart provided data feeds instead for the best performance: Real-Time Exchange Data Feeds Available From Sierra Chart There is a major performance improvement when using the Sierra Chart provided data feeds. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-03 02:33:13
[2019-11-04 19:25:40] |
Sierra Chart provided data feeds are "better" than IQ_Feed or the SC is optimized to work with them? I.E. IQ_Feed uses a client and Denali Exchange Data Feed does not? Sorry for the questions but IQ_Feed is a tier one data feed and I want to understand how SC provided feeds are better |
[2019-11-04 20:00:10] |
The Sierra Chart data feeds are better because they are provided in a much more efficient data format as compared to IQ Feed, in a directly usable binary format which requires no conversion as compared to IQ Feed with a text format which requires an inefficient conversion, and the processing of data is on a background thread with the Sierra Chart provided data feeds. The historical data downloading is on a background thread and does not interrupt the main thread and is multiple times faster than IQ Feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-04 20:02:04
