Date/Time: Sat, 18 Jan 2025 07:37:19 +0000
Overlay (Bar) study
View Count: 948
[2018-02-06 06:01:29] |
User509820 - Posts: 69 |
Hi, when I add the overlay(bar) study to the main chart. It is changing the corresponding chart I am using to overlay times settings to the main chart I am adding the study to. For example.. Main chart is 1min, I want to overlay a 5min chart to the 1min. When I add the study to the 1min it is changing the 5min to a 1min. Any suggestions? Thanks!
[2018-02-06 07:32:48] |
You need to use the Study/Price Overlay study instead.
