Date/Time: Sat, 18 Jan 2025 07:35:31 +0000
Can't reconnect to data feed
View Count: 762
[2018-02-06 01:39:47] |
User614121 - Posts: 1 |
Reading Internal Order ID file. | 2018-02-05 17:31:59 Reading Trade Orders file. | 2018-02-05 17:31:59 Reading Trade Positions file. | 2018-02-05 17:31:59 Listening on UDP port 22903. | 2018-02-05 17:31:59 Software version: 1697 | 2018-02-05 17:31:59 Usage end date: 2018-04-09 | 2018-02-05 17:31:59 Enabled for: Advanced Features. | 2018-02-05 17:31:59 Enabled for: Advanced Features 2. | 2018-02-05 17:31:59 Enabled for: Sierra Chart Historical Data Service. | 2018-02-05 17:31:59 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-02-05 17:31:59 Current selected Data/Trading service: GAIN Capital/OEC | 2018-02-05 17:31:59 Chart Update Interval: 500 | 2018-02-05 17:31:59 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-02-05 17:31:59 2018-02-05 17:32:05 Local computer time | 2018-02-05 17:31:59 2018-02-06 01:32:05 Local computer time in UTC | 2018-02-05 17:31:59 2018-02-05 17:32:05 Local computer time in SC Time Zone | 2018-02-05 17:31:59 2018-02-06 01:32:03 Server time in UTC | 2018-02-05 17:31:59 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-02-05 17:31:59 Program path: C:\SierraChart\ | 2018-02-05 17:31:59 Data Files path: C:\SierraChart\Data\ | 2018-02-05 17:31:59 OS Version Number: 6.1 | 2018-02-05 17:31:59 Locale Setting: C | 2018-02-05 17:31:59 Checking for new symbol settings for service code oec | 2018-02-05 17:31:59 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-02-05 17:31:59 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-02-05 17:31:59 Requesting symbol settings for service code oec. Overwrite = on. | 2018-02-05 17:31:59 Received 5 login tokens. | 2018-02-05 17:31:59 Symbol settings received. | 2018-02-05 17:32:06 Processed 1128 symbol settings. | 2018-02-05 17:32:06 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:07 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-02-05 17:32:07 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-02-05 17:32:11 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-02-05 17:32:11 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-02-05 17:32:11 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:11 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-02-05 17:32:11 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-02-05 17:32:11 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-02-05 17:32:11 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-02-05 17:32:11 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:11 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-02-05 17:32:11 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-02-05 17:32:13 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-02-05 17:32:13 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-02-05 17:32:13 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:13 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-02-05 17:32:13 Files to Open on Start up | File does not exist: C:\SierraChart\Data\demochartbook.cht | 2018-02-05 17:32:14 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:16 GAIN Capital FIX Trading socket (6) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:16 GAIN Capital FIX Trading socket (6) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:16 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:16 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:17 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:17 GAIN Capital FAST Data socket (7) | Creating socket. | 2018-02-05 17:32:17 GAIN Capital FAST Data socket (7) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:17 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:17 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:17 GAIN Capital FIX Trading socket (6) | Initiating close of socket by core. | 2018-02-05 17:32:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:17 GAIN Capital FIX Trading socket (6) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:17 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:17 GAIN Capital FAST Data socket (7) | Initiating close of socket by core. | 2018-02-05 17:32:17 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:17 GAIN Capital FAST Data socket (7) | Closed. | 2018-02-05 17:32:17 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:17 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:17 GAIN Capital FIX Trading socket (6) | Socket gracefully closed by remote side. | 2018-02-05 17:32:17 GAIN Capital FIX Trading socket (6) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:17 GAIN Capital FIX Trading socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:17 GAIN Capital FIX Trading socket (6) | Closed. | 2018-02-05 17:32:17 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:20 GAIN Capital FIX Trading socket (8) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:20 GAIN Capital FIX Trading socket (8) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:20 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:20 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:20 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:20 GAIN Capital FAST Data socket (9) | Creating socket. | 2018-02-05 17:32:20 GAIN Capital FAST Data socket (9) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:20 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:20 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:20 GAIN Capital FIX Trading socket (8) | Initiating close of socket by core. | 2018-02-05 17:32:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:20 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:20 GAIN Capital FIX Trading socket (8) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:20 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:20 GAIN Capital FAST Data socket (9) | Initiating close of socket by core. | 2018-02-05 17:32:20 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:20 GAIN Capital FAST Data socket (9) | Closed. | 2018-02-05 17:32:20 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:20 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:20 GAIN Capital FIX Trading socket (8) | Socket gracefully closed by remote side. | 2018-02-05 17:32:20 GAIN Capital FIX Trading socket (8) | Received socket Close event. | 2018-02-05 17:32:20 GAIN Capital FIX Trading socket (8) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:20 GAIN Capital FIX Trading socket (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:20 GAIN Capital FIX Trading socket (8) | Closed. | 2018-02-05 17:32:20 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:23 GAIN Capital FIX Trading socket (10) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:23 GAIN Capital FIX Trading socket (10) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:23 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:23 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:24 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:24 GAIN Capital FAST Data socket (11) | Creating socket. | 2018-02-05 17:32:24 GAIN Capital FAST Data socket (11) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:24 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:24 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:24 GAIN Capital FIX Trading socket (10) | Initiating close of socket by core. | 2018-02-05 17:32:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:24 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:24 GAIN Capital FIX Trading socket (10) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:24 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:24 GAIN Capital FAST Data socket (11) | Initiating close of socket by core. | 2018-02-05 17:32:24 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:24 GAIN Capital FAST Data socket (11) | Closed. | 2018-02-05 17:32:24 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:24 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:24 GAIN Capital FIX Trading socket (10) | Socket gracefully closed by remote side. | 2018-02-05 17:32:24 GAIN Capital FIX Trading socket (10) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:24 GAIN Capital FIX Trading socket (10) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:24 GAIN Capital FIX Trading socket (10) | Closed. | 2018-02-05 17:32:24 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:27 GAIN Capital FIX Trading socket (12) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:27 GAIN Capital FIX Trading socket (12) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:27 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:27 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:27 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:27 GAIN Capital FAST Data socket (13) | Creating socket. | 2018-02-05 17:32:27 GAIN Capital FAST Data socket (13) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:27 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:27 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:27 GAIN Capital FIX Trading socket (12) | Initiating close of socket by core. | 2018-02-05 17:32:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:27 GAIN Capital FIX Trading socket (12) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:27 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:27 GAIN Capital FAST Data socket (13) | Initiating close of socket by core. | 2018-02-05 17:32:27 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:27 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:27 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:27 GAIN Capital FAST Data socket (13) | Closed. | 2018-02-05 17:32:27 GAIN Capital FIX Trading socket (12) | Socket gracefully closed by remote side. | 2018-02-05 17:32:27 GAIN Capital FIX Trading socket (12) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:27 GAIN Capital FIX Trading socket (12) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:27 GAIN Capital FIX Trading socket (12) | Closed. | 2018-02-05 17:32:27 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:30 GAIN Capital FIX Trading socket (14) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:30 GAIN Capital FIX Trading socket (14) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:30 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:31 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:31 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:31 GAIN Capital FAST Data socket (15) | Creating socket. | 2018-02-05 17:32:31 GAIN Capital FAST Data socket (15) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:31 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:31 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:31 GAIN Capital FIX Trading socket (14) | Initiating close of socket by core. | 2018-02-05 17:32:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:31 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:31 GAIN Capital FIX Trading socket (14) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:31 GAIN Capital FAST Data socket (15) | Initiating close of socket by core. | 2018-02-05 17:32:31 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:31 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:31 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:31 GAIN Capital FAST Data socket (15) | Closed. | 2018-02-05 17:32:31 GAIN Capital FIX Trading socket (14) | Socket gracefully closed by remote side. | 2018-02-05 17:32:31 GAIN Capital FIX Trading socket (14) | Received socket Close event. | 2018-02-05 17:32:31 GAIN Capital FIX Trading socket (14) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:31 GAIN Capital FIX Trading socket (14) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:31 GAIN Capital FIX Trading socket (14) | Closed. | 2018-02-05 17:32:31 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:34 GAIN Capital FIX Trading socket (16) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:34 GAIN Capital FIX Trading socket (16) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:34 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:34 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:35 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:35 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:35 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:35 GAIN Capital FIX Trading socket (16) | Adding bytes from final send buffer from buffered socket: 108 | 2018-02-05 17:32:35 GAIN Capital FIX Trading socket (16) | Initiating close of socket by core. | 2018-02-05 17:32:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:35 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:35 GAIN Capital FIX Trading socket (16) | Sending bytes from final send buffer: 108 | 2018-02-05 17:32:35 GAIN Capital FIX Trading socket (16) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:35 GAIN Capital FAST Data socket (17) | Initiating close of socket by core. | 2018-02-05 17:32:35 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:35 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:35 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:35 GAIN Capital FIX Trading socket (16) | Socket gracefully closed by remote side. | 2018-02-05 17:32:35 GAIN Capital FIX Trading socket (16) | Received socket Close event. | 2018-02-05 17:32:35 GAIN Capital FIX Trading socket (16) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:35 GAIN Capital FIX Trading socket (16) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:35 GAIN Capital FIX Trading socket (16) | Closed. | 2018-02-05 17:32:35 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:38 GAIN Capital FIX Trading socket (18) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:38 GAIN Capital FIX Trading socket (18) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:38 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:38 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:39 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:39 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:39 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:39 GAIN Capital FIX Trading socket (18) | Adding bytes from final send buffer from buffered socket: 108 | 2018-02-05 17:32:39 GAIN Capital FIX Trading socket (18) | Initiating close of socket by core. | 2018-02-05 17:32:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:39 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:39 GAIN Capital FIX Trading socket (18) | Sending bytes from final send buffer: 108 | 2018-02-05 17:32:39 GAIN Capital FIX Trading socket (18) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:39 GAIN Capital FAST Data socket (19) | Initiating close of socket by core. | 2018-02-05 17:32:39 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:39 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:39 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:39 GAIN Capital FIX Trading socket (18) | Socket gracefully closed by remote side. | 2018-02-05 17:32:39 GAIN Capital FIX Trading socket (18) | Received socket Close event. | 2018-02-05 17:32:39 GAIN Capital FIX Trading socket (18) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:39 GAIN Capital FIX Trading socket (18) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:39 GAIN Capital FIX Trading socket (18) | Closed. | 2018-02-05 17:32:39 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:42 GAIN Capital FIX Trading socket (20) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:42 GAIN Capital FIX Trading socket (20) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:42 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:42 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:42 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:42 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:42 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:42 GAIN Capital FIX Trading socket (20) | Adding bytes from final send buffer from buffered socket: 108 | 2018-02-05 17:32:42 GAIN Capital FIX Trading socket (20) | Initiating close of socket by core. | 2018-02-05 17:32:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:42 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:42 GAIN Capital FIX Trading socket (20) | Sending bytes from final send buffer: 108 | 2018-02-05 17:32:42 GAIN Capital FIX Trading socket (20) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:42 GAIN Capital FAST Data socket (21) | Initiating close of socket by core. | 2018-02-05 17:32:42 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:42 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:42 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:42 GAIN Capital FIX Trading socket (20) | Socket gracefully closed by remote side. | 2018-02-05 17:32:42 GAIN Capital FIX Trading socket (20) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:42 GAIN Capital FIX Trading socket (20) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:42 GAIN Capital FIX Trading socket (20) | Closed. | 2018-02-05 17:32:42 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:45 GAIN Capital FIX Trading socket (22) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:45 GAIN Capital FIX Trading socket (22) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:45 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:46 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:46 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:46 GAIN Capital FAST Data socket (23) | Creating socket. | 2018-02-05 17:32:46 GAIN Capital FAST Data socket (23) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:46 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:46 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:46 GAIN Capital FIX Trading socket (22) | Adding bytes from final send buffer from buffered socket: 108 | 2018-02-05 17:32:46 GAIN Capital FIX Trading socket (22) | Initiating close of socket by core. | 2018-02-05 17:32:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:46 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:46 GAIN Capital FIX Trading socket (22) | Sending bytes from final send buffer: 108 | 2018-02-05 17:32:46 GAIN Capital FIX Trading socket (22) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:46 GAIN Capital FAST Data socket (23) | Initiating close of socket by core. | 2018-02-05 17:32:46 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:46 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:46 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:46 GAIN Capital FAST Data socket (23) | Closed. | 2018-02-05 17:32:46 GAIN Capital FIX Trading socket (22) | Socket gracefully closed by remote side. | 2018-02-05 17:32:46 GAIN Capital FIX Trading socket (22) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:46 GAIN Capital FIX Trading socket (22) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:46 GAIN Capital FIX Trading socket (22) | Closed. | 2018-02-05 17:32:46 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:49 GAIN Capital FIX Trading socket (24) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:49 GAIN Capital FIX Trading socket (24) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:49 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:49 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:49 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:49 GAIN Capital FAST Data socket (25) | Creating socket. | 2018-02-05 17:32:49 GAIN Capital FAST Data socket (25) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:49 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:49 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:49 GAIN Capital FIX Trading socket (24) | Initiating close of socket by core. | 2018-02-05 17:32:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:49 GAIN Capital FIX Trading socket (24) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:49 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:49 GAIN Capital FAST Data socket (25) | Initiating close of socket by core. | 2018-02-05 17:32:49 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:49 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:49 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:49 GAIN Capital FAST Data socket (25) | Closed. | 2018-02-05 17:32:49 GAIN Capital FIX Trading socket (24) | Socket gracefully closed by remote side. | 2018-02-05 17:32:49 GAIN Capital FIX Trading socket (24) | Received socket Close event. | 2018-02-05 17:32:49 GAIN Capital FIX Trading socket (24) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:49 GAIN Capital FIX Trading socket (24) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:49 GAIN Capital FIX Trading socket (24) | Closed. | 2018-02-05 17:32:49 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:52 GAIN Capital FIX Trading socket (26) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:52 GAIN Capital FIX Trading socket (26) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:52 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:53 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:53 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:53 GAIN Capital FAST Data socket (27) | Creating socket. | 2018-02-05 17:32:53 GAIN Capital FAST Data socket (27) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:53 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:53 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:53 GAIN Capital FIX Trading socket (26) | Adding bytes from final send buffer from buffered socket: 108 | 2018-02-05 17:32:53 GAIN Capital FIX Trading socket (26) | Initiating close of socket by core. | 2018-02-05 17:32:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:53 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:53 GAIN Capital FIX Trading socket (26) | Sending bytes from final send buffer: 108 | 2018-02-05 17:32:53 GAIN Capital FIX Trading socket (26) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:53 GAIN Capital FAST Data socket (27) | Initiating close of socket by core. | 2018-02-05 17:32:53 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:53 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:53 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:53 GAIN Capital FAST Data socket (27) | Closed. | 2018-02-05 17:32:53 GAIN Capital FIX Trading socket (26) | Socket gracefully closed by remote side. | 2018-02-05 17:32:53 GAIN Capital FIX Trading socket (26) | Received socket Close event. | 2018-02-05 17:32:53 GAIN Capital FIX Trading socket (26) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:53 GAIN Capital FIX Trading socket (26) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:53 GAIN Capital FIX Trading socket (26) | Closed. | 2018-02-05 17:32:53 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:56 GAIN Capital FIX Trading socket (28) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:56 GAIN Capital FIX Trading socket (28) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:56 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:32:56 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:32:56 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:32:56 GAIN Capital FAST Data socket (29) | Creating socket. | 2018-02-05 17:32:56 GAIN Capital FAST Data socket (29) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:56 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:32:56 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:32:56 GAIN Capital FIX Trading socket (28) | Initiating close of socket by core. | 2018-02-05 17:32:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:32:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:56 GAIN Capital FIX Trading socket (28) | Write in progress. Shutdown being delayed. | 2018-02-05 17:32:56 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:32:56 GAIN Capital FAST Data socket (29) | Initiating close of socket by core. | 2018-02-05 17:32:56 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:32:56 GAIN Capital FAST Data socket (29) | Closed. | 2018-02-05 17:32:56 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:32:56 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:32:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:32:56 GAIN Capital FIX Trading socket (28) | Socket gracefully closed by remote side. | 2018-02-05 17:32:56 GAIN Capital FIX Trading socket (28) | Write has completed. Shutdown being performed. | 2018-02-05 17:32:56 GAIN Capital FIX Trading socket (28) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:32:56 GAIN Capital FIX Trading socket (28) | Closed. | 2018-02-05 17:32:56 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:32:59 GAIN Capital FIX Trading socket (30) | Creating socket. Using TLS 1.2. | 2018-02-05 17:32:59 GAIN Capital FIX Trading socket (30) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:32:59 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:00 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:00 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:00 GAIN Capital FAST Data socket (31) | Creating socket. | 2018-02-05 17:33:00 GAIN Capital FAST Data socket (31) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:00 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:00 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:00 GAIN Capital FIX Trading socket (30) | Initiating close of socket by core. | 2018-02-05 17:33:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:00 GAIN Capital FIX Trading socket (30) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:00 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:00 GAIN Capital FAST Data socket (31) | Initiating close of socket by core. | 2018-02-05 17:33:00 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:00 GAIN Capital FAST Data socket (31) | Closed. | 2018-02-05 17:33:00 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:00 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:00 GAIN Capital FIX Trading socket (30) | Socket gracefully closed by remote side. | 2018-02-05 17:33:00 GAIN Capital FIX Trading socket (30) | Received socket Close event. | 2018-02-05 17:33:00 GAIN Capital FIX Trading socket (30) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:00 GAIN Capital FIX Trading socket (30) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:00 GAIN Capital FIX Trading socket (30) | Closed. | 2018-02-05 17:33:00 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:03 GAIN Capital FIX Trading socket (32) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:03 GAIN Capital FIX Trading socket (32) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:03 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:03 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:03 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:03 GAIN Capital FAST Data socket (34) | Creating socket. | 2018-02-05 17:33:03 GAIN Capital FAST Data socket (34) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:03 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:03 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:03 GAIN Capital FIX Trading socket (32) | Initiating close of socket by core. | 2018-02-05 17:33:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:03 GAIN Capital FIX Trading socket (32) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:03 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:03 GAIN Capital FAST Data socket (34) | Initiating close of socket by core. | 2018-02-05 17:33:03 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:03 GAIN Capital FAST Data socket (34) | Closed. | 2018-02-05 17:33:03 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:03 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:03 GAIN Capital FIX Trading socket (32) | Socket gracefully closed by remote side. | 2018-02-05 17:33:04 GAIN Capital FIX Trading socket (32) | Received socket Close event. | 2018-02-05 17:33:04 GAIN Capital FIX Trading socket (32) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:04 GAIN Capital FIX Trading socket (32) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:04 GAIN Capital FIX Trading socket (32) | Closed. | 2018-02-05 17:33:04 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:06 GAIN Capital FIX Trading socket (35) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:06 GAIN Capital FIX Trading socket (35) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:06 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:07 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:07 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:07 GAIN Capital FAST Data socket (36) | Creating socket. | 2018-02-05 17:33:07 GAIN Capital FAST Data socket (36) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:07 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:07 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:07 GAIN Capital FIX Trading socket (35) | Initiating close of socket by core. | 2018-02-05 17:33:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:07 GAIN Capital FIX Trading socket (35) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:07 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:07 GAIN Capital FAST Data socket (36) | Initiating close of socket by core. | 2018-02-05 17:33:07 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:07 GAIN Capital FAST Data socket (36) | Closed. | 2018-02-05 17:33:07 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:07 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:07 GAIN Capital FIX Trading socket (35) | Socket gracefully closed by remote side. | 2018-02-05 17:33:07 GAIN Capital FIX Trading socket (35) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:07 GAIN Capital FIX Trading socket (35) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:07 GAIN Capital FIX Trading socket (35) | Closed. | 2018-02-05 17:33:07 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:10 GAIN Capital FIX Trading socket (37) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:10 GAIN Capital FIX Trading socket (37) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:10 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:10 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:10 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:10 GAIN Capital FAST Data socket (38) | Creating socket. | 2018-02-05 17:33:10 GAIN Capital FAST Data socket (38) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:10 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:10 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:10 GAIN Capital FIX Trading socket (37) | Adding bytes from final send buffer from buffered socket: 108 | 2018-02-05 17:33:10 GAIN Capital FIX Trading socket (37) | Initiating close of socket by core. | 2018-02-05 17:33:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:10 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:10 GAIN Capital FIX Trading socket (37) | Sending bytes from final send buffer: 108 | 2018-02-05 17:33:10 GAIN Capital FIX Trading socket (37) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:10 GAIN Capital FAST Data socket (38) | Initiating close of socket by core. | 2018-02-05 17:33:10 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:10 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:10 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:10 GAIN Capital FAST Data socket (38) | Closed. | 2018-02-05 17:33:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:10 GAIN Capital FIX Trading socket (37) | Socket gracefully closed by remote side. | 2018-02-05 17:33:11 GAIN Capital FIX Trading socket (37) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:11 GAIN Capital FIX Trading socket (37) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:11 GAIN Capital FIX Trading socket (37) | Closed. | 2018-02-05 17:33:11 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:14 GAIN Capital FIX Trading socket (39) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:14 GAIN Capital FIX Trading socket (39) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:14 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:14 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:15 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:15 GAIN Capital FAST Data socket (40) | Creating socket. | 2018-02-05 17:33:15 GAIN Capital FAST Data socket (40) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:15 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:15 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:15 GAIN Capital FIX Trading socket (39) | Initiating close of socket by core. | 2018-02-05 17:33:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:15 GAIN Capital FIX Trading socket (39) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:15 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:15 GAIN Capital FAST Data socket (40) | Initiating close of socket by core. | 2018-02-05 17:33:15 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:15 GAIN Capital FAST Data socket (40) | Closed. | 2018-02-05 17:33:15 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:15 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:15 GAIN Capital FIX Trading socket (39) | Socket gracefully closed by remote side. | 2018-02-05 17:33:15 GAIN Capital FIX Trading socket (39) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:15 GAIN Capital FIX Trading socket (39) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:15 GAIN Capital FIX Trading socket (39) | Closed. | 2018-02-05 17:33:15 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:17 GAIN Capital FIX Trading socket (41) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:17 GAIN Capital FIX Trading socket (41) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:17 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:18 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:18 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:18 GAIN Capital FAST Data socket (42) | Creating socket. | 2018-02-05 17:33:18 GAIN Capital FAST Data socket (42) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:18 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:18 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:18 GAIN Capital FIX Trading socket (41) | Initiating close of socket by core. | 2018-02-05 17:33:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:18 GAIN Capital FIX Trading socket (41) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:18 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:18 GAIN Capital FAST Data socket (42) | Initiating close of socket by core. | 2018-02-05 17:33:18 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:18 GAIN Capital FAST Data socket (42) | Closed. | 2018-02-05 17:33:18 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:18 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:18 GAIN Capital FIX Trading socket (41) | Socket gracefully closed by remote side. | 2018-02-05 17:33:18 GAIN Capital FIX Trading socket (41) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:18 GAIN Capital FIX Trading socket (41) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:18 GAIN Capital FIX Trading socket (41) | Closed. | 2018-02-05 17:33:18 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:21 GAIN Capital FIX Trading socket (43) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:21 GAIN Capital FIX Trading socket (43) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:21 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:21 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:22 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:22 GAIN Capital FAST Data socket (44) | Creating socket. | 2018-02-05 17:33:22 GAIN Capital FAST Data socket (44) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:22 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:22 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:22 GAIN Capital FIX Trading socket (43) | Initiating close of socket by core. | 2018-02-05 17:33:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:22 GAIN Capital FIX Trading socket (43) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:22 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:22 GAIN Capital FAST Data socket (44) | Initiating close of socket by core. | 2018-02-05 17:33:22 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:22 GAIN Capital FAST Data socket (44) | Closed. | 2018-02-05 17:33:22 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:22 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:22 GAIN Capital FIX Trading socket (43) | Socket gracefully closed by remote side. | 2018-02-05 17:33:22 GAIN Capital FIX Trading socket (43) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:22 GAIN Capital FIX Trading socket (43) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:22 GAIN Capital FIX Trading socket (43) | Closed. | 2018-02-05 17:33:22 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:25 GAIN Capital FIX Trading socket (45) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:25 GAIN Capital FIX Trading socket (45) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:25 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:25 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:25 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:25 GAIN Capital FAST Data socket (46) | Creating socket. | 2018-02-05 17:33:25 GAIN Capital FAST Data socket (46) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:25 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:25 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:25 GAIN Capital FIX Trading socket (45) | Initiating close of socket by core. | 2018-02-05 17:33:25 GAIN Capital FIX Trading socket (45) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:25 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:25 GAIN Capital FAST Data socket (46) | Initiating close of socket by core. | 2018-02-05 17:33:25 GAIN Capital FAST Data socket (46) | Closed. | 2018-02-05 17:33:25 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:25 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:25 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:25 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:25 GAIN Capital FIX Trading socket (45) | Socket gracefully closed by remote side. | 2018-02-05 17:33:25 GAIN Capital FIX Trading socket (45) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:25 GAIN Capital FIX Trading socket (45) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:25 GAIN Capital FIX Trading socket (45) | Closed. | 2018-02-05 17:33:25 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:28 GAIN Capital FIX Trading socket (47) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:28 GAIN Capital FIX Trading socket (47) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:28 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:28 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:29 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:29 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:29 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:29 GAIN Capital FIX Trading socket (47) | Initiating close of socket by core. | 2018-02-05 17:33:29 GAIN Capital FIX Trading socket (47) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:29 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:29 GAIN Capital FAST Data socket (48) | Initiating close of socket by core. | 2018-02-05 17:33:29 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:29 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:29 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:29 GAIN Capital FIX Trading socket (47) | Socket gracefully closed by remote side. | 2018-02-05 17:33:29 GAIN Capital FIX Trading socket (47) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:29 GAIN Capital FIX Trading socket (47) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:29 GAIN Capital FIX Trading socket (47) | Closed. | 2018-02-05 17:33:29 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:32 GAIN Capital FIX Trading socket (49) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:32 GAIN Capital FIX Trading socket (49) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:32 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:32 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:32 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:32 GAIN Capital FAST Data socket (50) | Creating socket. | 2018-02-05 17:33:32 GAIN Capital FAST Data socket (50) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:32 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:32 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:32 GAIN Capital FIX Trading socket (49) | Initiating close of socket by core. | 2018-02-05 17:33:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:32 GAIN Capital FIX Trading socket (49) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:32 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:32 GAIN Capital FAST Data socket (50) | Initiating close of socket by core. | 2018-02-05 17:33:32 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:32 GAIN Capital FAST Data socket (50) | Closed. | 2018-02-05 17:33:32 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:32 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:32 GAIN Capital FIX Trading socket (49) | Socket gracefully closed by remote side. | 2018-02-05 17:33:32 GAIN Capital FIX Trading socket (49) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:32 GAIN Capital FIX Trading socket (49) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:32 GAIN Capital FIX Trading socket (49) | Closed. | 2018-02-05 17:33:32 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:35 GAIN Capital FIX Trading socket (51) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:35 GAIN Capital FIX Trading socket (51) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:35 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:35 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:36 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:36 GAIN Capital FAST Data socket (52) | Creating socket. | 2018-02-05 17:33:36 GAIN Capital FAST Data socket (52) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:36 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:36 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:36 GAIN Capital FIX Trading socket (51) | Initiating close of socket by core. | 2018-02-05 17:33:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:36 GAIN Capital FIX Trading socket (51) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:36 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:36 GAIN Capital FAST Data socket (52) | Initiating close of socket by core. | 2018-02-05 17:33:36 GAIN Capital FAST Data socket (52) | Closed. | 2018-02-05 17:33:36 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:36 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:36 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:36 GAIN Capital FIX Trading socket (51) | Socket gracefully closed by remote side. | 2018-02-05 17:33:36 GAIN Capital FIX Trading socket (51) | Received socket Close event. | 2018-02-05 17:33:36 GAIN Capital FIX Trading socket (51) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:36 GAIN Capital FIX Trading socket (51) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:36 GAIN Capital FIX Trading socket (51) | Closed. | 2018-02-05 17:33:36 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:39 GAIN Capital FIX Trading socket (53) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:39 GAIN Capital FIX Trading socket (53) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:39 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:39 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:39 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:39 GAIN Capital FAST Data socket (54) | Creating socket. | 2018-02-05 17:33:39 GAIN Capital FAST Data socket (54) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:39 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:39 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:39 GAIN Capital FIX Trading socket (53) | Initiating close of socket by core. | 2018-02-05 17:33:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:39 GAIN Capital FIX Trading socket (53) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:39 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:39 GAIN Capital FAST Data socket (54) | Initiating close of socket by core. | 2018-02-05 17:33:39 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:39 GAIN Capital FAST Data socket (54) | Closed. | 2018-02-05 17:33:39 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:39 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:39 GAIN Capital FIX Trading socket (53) | Socket gracefully closed by remote side. | 2018-02-05 17:33:39 GAIN Capital FIX Trading socket (53) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:39 GAIN Capital FIX Trading socket (53) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:39 GAIN Capital FIX Trading socket (53) | Closed. | 2018-02-05 17:33:39 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:42 GAIN Capital FIX Trading socket (55) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:42 GAIN Capital FIX Trading socket (55) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:42 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:42 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:43 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:43 GAIN Capital FAST Data socket (56) | Creating socket. | 2018-02-05 17:33:43 GAIN Capital FAST Data socket (56) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:43 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:43 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:43 GAIN Capital FIX Trading socket (55) | Initiating close of socket by core. | 2018-02-05 17:33:43 GAIN Capital FIX Trading socket (55) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:43 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:43 GAIN Capital FAST Data socket (56) | Initiating close of socket by core. | 2018-02-05 17:33:43 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:43 GAIN Capital FAST Data socket (56) | Closed. | 2018-02-05 17:33:43 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:43 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:43 GAIN Capital FIX Trading socket (55) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:43 GAIN Capital FIX Trading socket (55) | Shutdown started. Waiting for graceful close. | 2018-02-05 17:33:43 GAIN Capital FIX Trading socket (55) | Socket gracefully closed by remote side. | 2018-02-05 17:33:43 GAIN Capital FIX Trading socket (55) | Closed. | 2018-02-05 17:33:43 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:46 GAIN Capital FIX Trading socket (57) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:46 GAIN Capital FIX Trading socket (57) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:46 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:46 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:46 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:46 GAIN Capital FAST Data socket (58) | Creating socket. | 2018-02-05 17:33:46 GAIN Capital FAST Data socket (58) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:46 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:46 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:46 GAIN Capital FIX Trading socket (57) | Initiating close of socket by core. | 2018-02-05 17:33:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:46 GAIN Capital FIX Trading socket (57) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:46 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:46 GAIN Capital FAST Data socket (58) | Initiating close of socket by core. | 2018-02-05 17:33:46 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:46 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:46 GAIN Capital FAST Data socket (58) | Closed. | 2018-02-05 17:33:46 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:46 GAIN Capital FIX Trading socket (57) | Socket gracefully closed by remote side. | 2018-02-05 17:33:46 GAIN Capital FIX Trading socket (57) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:46 GAIN Capital FIX Trading socket (57) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:46 GAIN Capital FIX Trading socket (57) | Closed. | 2018-02-05 17:33:46 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:50 GAIN Capital FIX Trading socket (59) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:50 GAIN Capital FIX Trading socket (59) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:50 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:50 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:50 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:50 GAIN Capital FAST Data socket (60) | Creating socket. | 2018-02-05 17:33:50 GAIN Capital FAST Data socket (60) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:50 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:50 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:50 GAIN Capital FIX Trading socket (59) | Initiating close of socket by core. | 2018-02-05 17:33:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:50 GAIN Capital FIX Trading socket (59) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:50 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:50 GAIN Capital FAST Data socket (60) | Initiating close of socket by core. | 2018-02-05 17:33:50 GAIN Capital FAST Data socket (60) | Closed. | 2018-02-05 17:33:50 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:50 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:50 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:50 GAIN Capital FIX Trading socket (59) | Socket gracefully closed by remote side. | 2018-02-05 17:33:50 GAIN Capital FIX Trading socket (59) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:50 GAIN Capital FIX Trading socket (59) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:50 GAIN Capital FIX Trading socket (59) | Closed. | 2018-02-05 17:33:50 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:53 GAIN Capital FIX Trading socket (61) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:53 GAIN Capital FIX Trading socket (61) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:53 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:53 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:54 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:54 GAIN Capital FAST Data socket (62) | Creating socket. | 2018-02-05 17:33:54 GAIN Capital FAST Data socket (62) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:54 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:54 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:54 GAIN Capital FIX Trading socket (61) | Initiating close of socket by core. | 2018-02-05 17:33:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:54 GAIN Capital FIX Trading socket (61) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:54 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:54 GAIN Capital FAST Data socket (62) | Initiating close of socket by core. | 2018-02-05 17:33:54 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:54 GAIN Capital FAST Data socket (62) | Closed. | 2018-02-05 17:33:54 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:54 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:54 GAIN Capital FIX Trading socket (61) | Socket gracefully closed by remote side. | 2018-02-05 17:33:54 GAIN Capital FIX Trading socket (61) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:54 GAIN Capital FIX Trading socket (61) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:54 GAIN Capital FIX Trading socket (61) | Closed. | 2018-02-05 17:33:54 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:33:57 GAIN Capital FIX Trading socket (63) | Creating socket. Using TLS 1.2. | 2018-02-05 17:33:57 GAIN Capital FIX Trading socket (63) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:57 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:33:57 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:33:57 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:33:57 GAIN Capital FAST Data socket (64) | Creating socket. | 2018-02-05 17:33:57 GAIN Capital FAST Data socket (64) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:33:57 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:33:57 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:33:57 GAIN Capital FIX Trading socket (63) | Initiating close of socket by core. | 2018-02-05 17:33:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:33:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:57 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:33:57 GAIN Capital FIX Trading socket (63) | Write in progress. Shutdown being delayed. | 2018-02-05 17:33:57 GAIN Capital FAST Data socket (64) | Initiating close of socket by core. | 2018-02-05 17:33:57 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:33:57 GAIN Capital FAST Data socket (64) | Closed. | 2018-02-05 17:33:57 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:33:57 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:33:57 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:33:57 GAIN Capital FIX Trading socket (63) | Socket gracefully closed by remote side. | 2018-02-05 17:33:57 GAIN Capital FIX Trading socket (63) | Received socket Close event. | 2018-02-05 17:33:57 GAIN Capital FIX Trading socket (63) | Write has completed. Shutdown being performed. | 2018-02-05 17:33:57 GAIN Capital FIX Trading socket (63) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:33:57 GAIN Capital FIX Trading socket (63) | Closed. | 2018-02-05 17:33:57 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:00 GAIN Capital FIX Trading socket (65) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:00 GAIN Capital FIX Trading socket (65) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:00 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:00 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:01 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:01 GAIN Capital FAST Data socket (66) | Creating socket. | 2018-02-05 17:34:01 GAIN Capital FAST Data socket (66) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:01 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:01 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:01 GAIN Capital FIX Trading socket (65) | Initiating close of socket by core. | 2018-02-05 17:34:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:01 GAIN Capital FIX Trading socket (65) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:01 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:01 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:01 GAIN Capital FAST Data socket (66) | Initiating close of socket by core. | 2018-02-05 17:34:01 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:01 GAIN Capital FAST Data socket (66) | Closed. | 2018-02-05 17:34:01 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:01 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:01 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:01 GAIN Capital FIX Trading socket (65) | Socket gracefully closed by remote side. | 2018-02-05 17:34:01 GAIN Capital FIX Trading socket (65) | Received socket Close event. | 2018-02-05 17:34:01 GAIN Capital FIX Trading socket (65) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:01 GAIN Capital FIX Trading socket (65) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:01 GAIN Capital FIX Trading socket (65) | Closed. | 2018-02-05 17:34:01 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:04 GAIN Capital FIX Trading socket (68) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:04 GAIN Capital FIX Trading socket (68) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:04 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:04 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:04 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:04 GAIN Capital FAST Data socket (69) | Creating socket. | 2018-02-05 17:34:04 GAIN Capital FAST Data socket (69) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:04 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:04 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:04 GAIN Capital FIX Trading socket (68) | Initiating close of socket by core. | 2018-02-05 17:34:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:04 GAIN Capital FIX Trading socket (68) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:04 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:04 GAIN Capital FAST Data socket (69) | Initiating close of socket by core. | 2018-02-05 17:34:04 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:04 GAIN Capital FAST Data socket (69) | Closed. | 2018-02-05 17:34:04 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:04 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:04 GAIN Capital FIX Trading socket (68) | Socket gracefully closed by remote side. | 2018-02-05 17:34:05 GAIN Capital FIX Trading socket (68) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:05 GAIN Capital FIX Trading socket (68) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:05 GAIN Capital FIX Trading socket (68) | Closed. | 2018-02-05 17:34:05 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:07 GAIN Capital FIX Trading socket (70) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:07 GAIN Capital FIX Trading socket (70) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:07 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:08 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:08 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:08 GAIN Capital FAST Data socket (71) | Creating socket. | 2018-02-05 17:34:08 GAIN Capital FAST Data socket (71) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:08 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:08 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:08 GAIN Capital FIX Trading socket (70) | Initiating close of socket by core. | 2018-02-05 17:34:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:08 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:08 GAIN Capital FIX Trading socket (70) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:08 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:08 GAIN Capital FAST Data socket (71) | Initiating close of socket by core. | 2018-02-05 17:34:08 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:08 GAIN Capital FAST Data socket (71) | Closed. | 2018-02-05 17:34:08 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:08 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:08 GAIN Capital FIX Trading socket (70) | Socket gracefully closed by remote side. | 2018-02-05 17:34:09 GAIN Capital FIX Trading socket (70) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:09 GAIN Capital FIX Trading socket (70) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:09 GAIN Capital FIX Trading socket (70) | Closed. | 2018-02-05 17:34:09 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:11 GAIN Capital FIX Trading socket (72) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:11 GAIN Capital FIX Trading socket (72) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:11 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:12 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:12 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:12 GAIN Capital FAST Data socket (73) | Creating socket. | 2018-02-05 17:34:12 GAIN Capital FAST Data socket (73) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:12 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:12 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:12 GAIN Capital FIX Trading socket (72) | Initiating close of socket by core. | 2018-02-05 17:34:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:12 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:12 GAIN Capital FIX Trading socket (72) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:12 GAIN Capital FAST Data socket (73) | Initiating close of socket by core. | 2018-02-05 17:34:12 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:12 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:12 GAIN Capital FAST Data socket (73) | Closed. | 2018-02-05 17:34:12 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:12 GAIN Capital FIX Trading socket (72) | Socket gracefully closed by remote side. | 2018-02-05 17:34:12 GAIN Capital FIX Trading socket (72) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:12 GAIN Capital FIX Trading socket (72) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:12 GAIN Capital FIX Trading socket (72) | Closed. | 2018-02-05 17:34:12 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:15 GAIN Capital FIX Trading socket (74) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:15 GAIN Capital FIX Trading socket (74) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:15 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:15 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:15 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:15 GAIN Capital FAST Data socket (75) | Creating socket. | 2018-02-05 17:34:15 GAIN Capital FAST Data socket (75) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:15 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:15 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:15 GAIN Capital FIX Trading socket (74) | Initiating close of socket by core. | 2018-02-05 17:34:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:15 GAIN Capital FIX Trading socket (74) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:15 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:15 GAIN Capital FAST Data socket (75) | Initiating close of socket by core. | 2018-02-05 17:34:15 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:15 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:15 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:15 GAIN Capital FAST Data socket (75) | Closed. | 2018-02-05 17:34:15 GAIN Capital FIX Trading socket (74) | Socket gracefully closed by remote side. | 2018-02-05 17:34:15 GAIN Capital FIX Trading socket (74) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:15 GAIN Capital FIX Trading socket (74) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:15 GAIN Capital FIX Trading socket (74) | Closed. | 2018-02-05 17:34:15 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:18 GAIN Capital FIX Trading socket (76) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:18 GAIN Capital FIX Trading socket (76) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:18 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:19 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:19 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:19 GAIN Capital FAST Data socket (77) | Creating socket. | 2018-02-05 17:34:19 GAIN Capital FAST Data socket (77) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:19 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:19 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:19 GAIN Capital FIX Trading socket (76) | Initiating close of socket by core. | 2018-02-05 17:34:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:19 GAIN Capital FIX Trading socket (76) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:19 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:19 GAIN Capital FAST Data socket (77) | Initiating close of socket by core. | 2018-02-05 17:34:19 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:19 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:19 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:19 GAIN Capital FAST Data socket (77) | Closed. | 2018-02-05 17:34:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:19 GAIN Capital FIX Trading socket (76) | Socket gracefully closed by remote side. | 2018-02-05 17:34:19 GAIN Capital FIX Trading socket (76) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:19 GAIN Capital FIX Trading socket (76) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:19 GAIN Capital FIX Trading socket (76) | Closed. | 2018-02-05 17:34:19 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:22 GAIN Capital FIX Trading socket (78) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:22 GAIN Capital FIX Trading socket (78) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:22 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:22 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:22 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:22 GAIN Capital FAST Data socket (79) | Creating socket. | 2018-02-05 17:34:22 GAIN Capital FAST Data socket (79) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:22 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:22 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:22 GAIN Capital FIX Trading socket (78) | Initiating close of socket by core. | 2018-02-05 17:34:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:22 GAIN Capital FIX Trading socket (78) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:22 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:22 GAIN Capital FAST Data socket (79) | Initiating close of socket by core. | 2018-02-05 17:34:22 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:22 GAIN Capital FAST Data socket (79) | Closed. | 2018-02-05 17:34:22 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:22 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:22 GAIN Capital FIX Trading socket (78) | Socket gracefully closed by remote side. | 2018-02-05 17:34:22 GAIN Capital FIX Trading socket (78) | Received socket Close event. | 2018-02-05 17:34:22 GAIN Capital FIX Trading socket (78) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:22 GAIN Capital FIX Trading socket (78) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:22 GAIN Capital FIX Trading socket (78) | Closed. | 2018-02-05 17:34:22 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:25 GAIN Capital FIX Trading socket (80) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:25 GAIN Capital FIX Trading socket (80) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:25 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:26 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:26 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:26 GAIN Capital FAST Data socket (81) | Creating socket. | 2018-02-05 17:34:26 GAIN Capital FAST Data socket (81) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:26 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:26 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:26 GAIN Capital FIX Trading socket (80) | Initiating close of socket by core. | 2018-02-05 17:34:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:26 GAIN Capital FIX Trading socket (80) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:26 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:26 GAIN Capital FAST Data socket (81) | Initiating close of socket by core. | 2018-02-05 17:34:26 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:26 GAIN Capital FAST Data socket (81) | Closed. | 2018-02-05 17:34:26 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:26 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:26 GAIN Capital FIX Trading socket (80) | Socket gracefully closed by remote side. | 2018-02-05 17:34:26 GAIN Capital FIX Trading socket (80) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:26 GAIN Capital FIX Trading socket (80) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:26 GAIN Capital FIX Trading socket (80) | Closed. | 2018-02-05 17:34:26 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:29 GAIN Capital FIX Trading socket (82) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:29 GAIN Capital FIX Trading socket (82) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:29 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:30 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:30 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:30 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:30 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:30 GAIN Capital FIX Trading socket (82) | Initiating close of socket by core. | 2018-02-05 17:34:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:30 GAIN Capital FIX Trading socket (82) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:30 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:30 GAIN Capital FAST Data socket (83) | Initiating close of socket by core. | 2018-02-05 17:34:30 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:30 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:30 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:30 GAIN Capital FIX Trading socket (82) | Socket gracefully closed by remote side. | 2018-02-05 17:34:30 GAIN Capital FIX Trading socket (82) | Received socket Close event. | 2018-02-05 17:34:30 GAIN Capital FIX Trading socket (82) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:30 GAIN Capital FIX Trading socket (82) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:30 GAIN Capital FIX Trading socket (82) | Closed. | 2018-02-05 17:34:30 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:33 GAIN Capital FIX Trading socket (84) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:33 GAIN Capital FIX Trading socket (84) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:33 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:33 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:33 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:33 GAIN Capital FAST Data socket (85) | Creating socket. | 2018-02-05 17:34:33 GAIN Capital FAST Data socket (85) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:33 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:33 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:33 GAIN Capital FIX Trading socket (84) | Initiating close of socket by core. | 2018-02-05 17:34:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:33 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:33 GAIN Capital FIX Trading socket (84) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:33 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:33 GAIN Capital FAST Data socket (85) | Initiating close of socket by core. | 2018-02-05 17:34:33 GAIN Capital FAST Data socket (85) | Closed. | 2018-02-05 17:34:33 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:33 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:33 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:33 GAIN Capital FIX Trading socket (84) | Socket gracefully closed by remote side. | 2018-02-05 17:34:33 GAIN Capital FIX Trading socket (84) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:33 GAIN Capital FIX Trading socket (84) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:33 GAIN Capital FIX Trading socket (84) | Closed. | 2018-02-05 17:34:33 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:36 GAIN Capital FIX Trading socket (86) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:36 GAIN Capital FIX Trading socket (86) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:36 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:37 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:37 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:37 GAIN Capital FAST Data socket (87) | Creating socket. | 2018-02-05 17:34:37 GAIN Capital FAST Data socket (87) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:37 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:37 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:37 GAIN Capital FIX Trading socket (86) | Initiating close of socket by core. | 2018-02-05 17:34:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:37 GAIN Capital FIX Trading socket (86) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:37 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:37 GAIN Capital FAST Data socket (87) | Initiating close of socket by core. | 2018-02-05 17:34:37 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:37 GAIN Capital FAST Data socket (87) | Closed. | 2018-02-05 17:34:37 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:37 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:37 GAIN Capital FIX Trading socket (86) | Socket gracefully closed by remote side. | 2018-02-05 17:34:37 GAIN Capital FIX Trading socket (86) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:37 GAIN Capital FIX Trading socket (86) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:37 GAIN Capital FIX Trading socket (86) | Closed. | 2018-02-05 17:34:37 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:40 GAIN Capital FIX Trading socket (88) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:40 GAIN Capital FIX Trading socket (88) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:40 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:40 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:40 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:40 GAIN Capital FAST Data socket (89) | Creating socket. | 2018-02-05 17:34:40 GAIN Capital FAST Data socket (89) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:40 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:40 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:40 GAIN Capital FIX Trading socket (88) | Initiating close of socket by core. | 2018-02-05 17:34:40 GAIN Capital FIX Trading socket (88) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:40 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:40 GAIN Capital FAST Data socket (89) | Initiating close of socket by core. | 2018-02-05 17:34:40 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:40 GAIN Capital FAST Data socket (89) | Closed. | 2018-02-05 17:34:40 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:40 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:40 GAIN Capital FIX Trading socket (88) | Socket gracefully closed by remote side. | 2018-02-05 17:34:40 GAIN Capital FIX Trading socket (88) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:40 GAIN Capital FIX Trading socket (88) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:40 GAIN Capital FIX Trading socket (88) | Closed. | 2018-02-05 17:34:40 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:43 GAIN Capital FIX Trading socket (90) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:43 GAIN Capital FIX Trading socket (90) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:43 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:44 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:44 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:44 GAIN Capital FAST Data socket (91) | Creating socket. | 2018-02-05 17:34:44 GAIN Capital FAST Data socket (91) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:44 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:44 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:44 GAIN Capital FIX Trading socket (90) | Initiating close of socket by core. | 2018-02-05 17:34:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:44 GAIN Capital FIX Trading socket (90) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:44 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:44 GAIN Capital FAST Data socket (91) | Initiating close of socket by core. | 2018-02-05 17:34:44 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:44 GAIN Capital FAST Data socket (91) | Closed. | 2018-02-05 17:34:44 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:44 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:44 GAIN Capital FIX Trading socket (90) | Socket gracefully closed by remote side. | 2018-02-05 17:34:44 GAIN Capital FIX Trading socket (90) | Received socket Close event. | 2018-02-05 17:34:44 GAIN Capital FIX Trading socket (90) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:44 GAIN Capital FIX Trading socket (90) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:44 GAIN Capital FIX Trading socket (90) | Closed. | 2018-02-05 17:34:44 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:47 GAIN Capital FIX Trading socket (92) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:47 GAIN Capital FIX Trading socket (92) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:47 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:47 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:47 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:47 GAIN Capital FAST Data socket (93) | Creating socket. | 2018-02-05 17:34:47 GAIN Capital FAST Data socket (93) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:47 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:47 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:47 GAIN Capital FIX Trading socket (92) | Initiating close of socket by core. | 2018-02-05 17:34:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:47 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:47 GAIN Capital FIX Trading socket (92) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:47 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:47 GAIN Capital FAST Data socket (93) | Initiating close of socket by core. | 2018-02-05 17:34:47 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:47 GAIN Capital FAST Data socket (93) | Closed. | 2018-02-05 17:34:47 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:47 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:47 GAIN Capital FIX Trading socket (92) | Socket gracefully closed by remote side. | 2018-02-05 17:34:47 GAIN Capital FIX Trading socket (92) | Received socket Close event. | 2018-02-05 17:34:47 GAIN Capital FIX Trading socket (92) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:47 GAIN Capital FIX Trading socket (92) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:47 GAIN Capital FIX Trading socket (92) | Closed. | 2018-02-05 17:34:47 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:50 GAIN Capital FIX Trading socket (94) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:50 GAIN Capital FIX Trading socket (94) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:50 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:51 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:51 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:51 GAIN Capital FAST Data socket (95) | Creating socket. | 2018-02-05 17:34:51 GAIN Capital FAST Data socket (95) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:51 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:51 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:51 GAIN Capital FIX Trading socket (94) | Initiating close of socket by core. | 2018-02-05 17:34:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:51 GAIN Capital FIX Trading socket (94) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:51 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:51 GAIN Capital FAST Data socket (95) | Initiating close of socket by core. | 2018-02-05 17:34:51 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:51 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:51 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:51 GAIN Capital FAST Data socket (95) | Closed. | 2018-02-05 17:34:51 GAIN Capital FIX Trading socket (94) | Socket gracefully closed by remote side. | 2018-02-05 17:34:51 GAIN Capital FIX Trading socket (94) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:51 GAIN Capital FIX Trading socket (94) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:51 GAIN Capital FIX Trading socket (94) | Closed. | 2018-02-05 17:34:51 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:54 GAIN Capital FIX Trading socket (96) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:54 GAIN Capital FIX Trading socket (96) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:54 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:55 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:55 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:55 GAIN Capital FAST Data socket (97) | Creating socket. | 2018-02-05 17:34:55 GAIN Capital FAST Data socket (97) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:55 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:55 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:55 GAIN Capital FIX Trading socket (96) | Initiating close of socket by core. | 2018-02-05 17:34:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:55 GAIN Capital FIX Trading socket (96) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:55 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:55 GAIN Capital FAST Data socket (97) | Initiating close of socket by core. | 2018-02-05 17:34:55 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:55 GAIN Capital FAST Data socket (97) | Closed. | 2018-02-05 17:34:55 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:55 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:55 GAIN Capital FIX Trading socket (96) | Socket gracefully closed by remote side. | 2018-02-05 17:34:55 GAIN Capital FIX Trading socket (96) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:55 GAIN Capital FIX Trading socket (96) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:55 GAIN Capital FIX Trading socket (96) | Closed. | 2018-02-05 17:34:55 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:34:58 GAIN Capital FIX Trading socket (98) | Creating socket. Using TLS 1.2. | 2018-02-05 17:34:58 GAIN Capital FIX Trading socket (98) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:58 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:34:58 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:34:58 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:34:58 GAIN Capital FAST Data socket (99) | Creating socket. | 2018-02-05 17:34:58 GAIN Capital FAST Data socket (99) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:34:58 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:34:58 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:34:58 GAIN Capital FIX Trading socket (98) | Initiating close of socket by core. | 2018-02-05 17:34:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:34:58 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:58 GAIN Capital FIX Trading socket (98) | Write in progress. Shutdown being delayed. | 2018-02-05 17:34:58 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:34:58 GAIN Capital FAST Data socket (99) | Initiating close of socket by core. | 2018-02-05 17:34:58 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:34:58 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:34:58 GAIN Capital FAST Data socket (99) | Closed. | 2018-02-05 17:34:58 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:34:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:34:58 GAIN Capital FIX Trading socket (98) | Socket gracefully closed by remote side. | 2018-02-05 17:34:58 GAIN Capital FIX Trading socket (98) | Write has completed. Shutdown being performed. | 2018-02-05 17:34:58 GAIN Capital FIX Trading socket (98) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:34:58 GAIN Capital FIX Trading socket (98) | Closed. | 2018-02-05 17:34:58 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:35:01 GAIN Capital FIX Trading socket (100) | Creating socket. Using TLS 1.2. | 2018-02-05 17:35:01 GAIN Capital FIX Trading socket (100) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:35:01 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:35:02 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:35:02 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:35:02 GAIN Capital FAST Data socket (101) | Creating socket. | 2018-02-05 17:35:02 GAIN Capital FAST Data socket (101) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:35:02 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:35:02 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:35:02 GAIN Capital FIX Trading socket (100) | Initiating close of socket by core. | 2018-02-05 17:35:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:35:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:35:02 GAIN Capital FIX Trading socket (100) | Write in progress. Shutdown being delayed. | 2018-02-05 17:35:02 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:35:02 GAIN Capital FAST Data socket (101) | Initiating close of socket by core. | 2018-02-05 17:35:02 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:35:02 GAIN Capital FAST Data socket (101) | Closed. | 2018-02-05 17:35:02 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:35:02 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:35:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:35:02 GAIN Capital FIX Trading socket (100) | Socket gracefully closed by remote side. | 2018-02-05 17:35:02 GAIN Capital FIX Trading socket (100) | Received socket Close event. | 2018-02-05 17:35:02 GAIN Capital FIX Trading socket (100) | Write has completed. Shutdown being performed. | 2018-02-05 17:35:02 GAIN Capital FIX Trading socket (100) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:35:02 GAIN Capital FIX Trading socket (100) | Closed. | 2018-02-05 17:35:02 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:35:05 GAIN Capital FIX Trading socket (103) | Creating socket. Using TLS 1.2. | 2018-02-05 17:35:05 GAIN Capital FIX Trading socket (103) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:35:05 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:35:05 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:35:06 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:35:06 GAIN Capital FAST Data socket (104) | Creating socket. | 2018-02-05 17:35:06 GAIN Capital FAST Data socket (104) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:35:06 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:35:06 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:35:06 GAIN Capital FIX Trading socket (103) | Initiating close of socket by core. | 2018-02-05 17:35:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:35:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:35:06 GAIN Capital FIX Trading socket (103) | Write in progress. Shutdown being delayed. | 2018-02-05 17:35:06 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:35:06 GAIN Capital FAST Data socket (104) | Initiating close of socket by core. | 2018-02-05 17:35:06 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:35:06 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:35:06 GAIN Capital FAST Data socket (104) | Closed. | 2018-02-05 17:35:06 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:35:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:35:06 GAIN Capital FIX Trading socket (103) | Write has completed. Shutdown being performed. | 2018-02-05 17:35:06 GAIN Capital FIX Trading socket (103) | Shutdown started. Waiting for graceful close. | 2018-02-05 17:35:06 GAIN Capital FIX Trading socket (103) | Socket gracefully closed by remote side. | 2018-02-05 17:35:06 GAIN Capital FIX Trading socket (103) | Closed. | 2018-02-05 17:35:06 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:35:09 GAIN Capital FIX Trading socket (105) | Creating socket. Using TLS 1.2. | 2018-02-05 17:35:09 GAIN Capital FIX Trading socket (105) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:35:09 GAIN Capital FIX Trading: Sending the Logon message. | 2018-02-05 17:35:09 GAIN Capital FIX Trading | Connected to trading server. | 2018-02-05 17:35:09 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2018-02-05 17:35:09 GAIN Capital FAST Data socket (106) | Creating socket. | 2018-02-05 17:35:09 GAIN Capital FAST Data socket (106) | Connecting to IP: 64.94.37.222. | 2018-02-05 17:35:09 GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:35:09 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2018-02-05 17:35:09 GAIN Capital FIX Trading socket (105) | Initiating close of socket by core. | 2018-02-05 17:35:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:35:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:35:09 GAIN Capital FIX Trading socket (105) | Write in progress. Shutdown being delayed. | 2018-02-05 17:35:09 GAIN Capital/OEC | Disconnected from the trading server. | 2018-02-05 17:35:09 GAIN Capital FAST Data socket (106) | Initiating close of socket by core. | 2018-02-05 17:35:09 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2018-02-05 17:35:09 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2018-02-05 17:35:09 GAIN Capital/OEC | Disconnected. | 2018-02-05 17:35:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:35:09 GAIN Capital FAST Data socket (106) | Closed. | 2018-02-05 17:35:09 GAIN Capital FIX Trading socket (105) | Socket gracefully closed by remote side. | 2018-02-05 17:35:09 GAIN Capital FIX Trading socket (105) | Write has completed. Shutdown being performed. | 2018-02-05 17:35:09 GAIN Capital FIX Trading socket (105) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:35:09 GAIN Capital FIX Trading socket (105) | Closed. | 2018-02-05 17:35:09 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2018-02-05 17:35:12 |
[2018-02-06 02:58:46] |
This is what we see: GAIN Capital FIX Trading: Received a Logout message. Text = User connected from another location | 2018-02-05 17:35:09
Refer to: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem If you need further help you will need to contact Gain Capital. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
