Date/Time: Sat, 18 Jan 2025 08:01:34 +0000
I can't connect to ONEUPTRADER via Ritmic
View Count: 1175
[2018-02-05 16:34:30] |
User84094 - Posts: 47 |
How can I connect to ONEUPTRADER via Ritmic ? Reading Internal Order ID file. | 2018-02-05 17:58:12 Reading Trade Orders file. | 2018-02-05 17:58:12 Reading Trade Positions file. | 2018-02-05 17:58:12 Listening on UDP port 22903. | 2018-02-05 17:58:12 Software version: 1616 | 2018-02-05 17:58:12 Usage end date: 2018-03-16 | 2018-02-05 17:58:12 Enabled for: Advanced Features. | 2018-02-05 17:58:12 Enabled for: Sierra Chart Historical Data Service. | 2018-02-05 17:58:12 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-02-05 17:58:12 Current selected Data/Trading service: Rithmic Trading | 2018-02-05 17:58:12 Chart Update Interval: 500 | 2018-02-05 17:58:12 Time Zone: +02:00:00 (GMT+02DT+01,M3.5.0/02:00,M10.5.0/02:00) | 2018-02-05 17:58:12 2018-02-05 17:58:17 Local computer time | 2018-02-05 17:58:12 2018-02-05 15:58:17 Local computer time in UTC | 2018-02-05 17:58:12 2018-02-05 17:58:17 Local computer time in SC Time Zone | 2018-02-05 17:58:12 2018-02-05 15:58:19 Server time in UTC | 2018-02-05 17:58:12 Local computer UTC time and Server UTC time difference: 3 seconds. | 2018-02-05 17:58:12 Program path: C:\SierraChart3\ | 2018-02-05 17:58:12 Data Files path: C:\SierraChart3\Data\ | 2018-02-05 17:58:12 OS Version Number: 6.0 | 2018-02-05 17:58:12 Locale Setting: C | 2018-02-05 17:58:12 Created the DTC Protocol server. | 2018-02-05 17:58:12 DTC Protocol Server listening on port 11099. | 2018-02-05 17:58:12 Created the DTC Protocol historical data server. | 2018-02-05 17:58:12 HD Server Manager | Listening on port 11098 | 2018-02-05 17:58:12 Checking for new symbol settings for service code rim | 2018-02-05 17:58:12 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-02-05 17:58:12 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-02-05 17:58:12 Received 5 login tokens. | 2018-02-05 17:58:18 Symbol settings are up-to-date for rim | 2018-02-05 17:58:18 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-02-05 17:58:19 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-02-05 17:58:19 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-02-05 17:58:23 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-02-05 17:58:23 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:58:23 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-02-05 17:58:23 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-02-05 17:58:23 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-02-05 17:58:23 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:58:23 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-02-05 17:58:23 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-02-05 17:58:25 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-02-05 17:58:25 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-02-05 17:58:25 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-02-05 17:58:25 Files to Open on Start up | Opening file: UB.cht | 2018-02-05 17:58:26 UB.20180300.CME_F [CV] Flex Renko 2-1-1-x #1 | Reloading chart. | 2018-02-05 17:58:26 UB.20180300.CME_F [CV] Flex Renko 2-1-1-x #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2018-02-05 17:58:26 UB.20180300.CME_F [CV] Flex Renko 2-1-1-x #1 | There are no continuous futures contract symbols. Loading data normally. | 2018-02-05 17:58:26 Rithmic Trading | Port for executable: 51196 | 2018-02-05 17:58:28 Listening socket (700). Port 51196 | Closed. | 2018-02-05 17:58:28 Rithmic Trading | Starting server: C:\SierraChart3\Rim\DTCBridge.exe | 2018-02-05 17:58:28 Rithmic Trading | Bridge process is running. | 2018-02-05 17:58:30 Rithmic Trading | Connecting to the server 127.0.0.1. Port 51196 | 2018-02-05 17:58:30 DTC Client socket (6) | Creating socket. | 2018-02-05 17:58:30 DTC Client socket (6) | Connecting to IP: 127.0.0.1. | 2018-02-05 17:58:30 DTC Client socket (6) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-02-05 17:58:31 * DTC Client socket (6) | Initiating close of socket by core. | 2018-02-05 17:58:31 DTC Client socket (6) | Closed. | 2018-02-05 17:58:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 17:58:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:58:31 Rithmic Trading | Disconnected. | 2018-02-05 17:58:31 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 17:58:31 Rithmic Trading | Port for executable: 51199 | 2018-02-05 17:58:33 Listening socket (712). Port 51199 | Closed. | 2018-02-05 17:58:33 Rithmic Trading | Starting server: C:\SierraChart3\Rim\DTCBridge.exe | 2018-02-05 17:58:33 File >> Disconnect selected. | 2018-02-05 17:58:35 Rithmic Trading | Disconnected. | 2018-02-05 17:58:35 Rithmic Trading | Port for executable: 52282 | 2018-02-05 18:28:36 Listening socket (488). Port 52282 | Closed. | 2018-02-05 18:28:36 Rithmic Trading | Starting server: C:\SierraChart3\Rim\DTCBridge.exe | 2018-02-05 18:28:36 Rithmic Trading | Bridge process is running. | 2018-02-05 18:28:38 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52282 | 2018-02-05 18:28:38 DTC Client socket (37) | Creating socket. | 2018-02-05 18:28:38 DTC Client socket (37) | Connecting to IP: 127.0.0.1. | 2018-02-05 18:28:38 DTC Client socket (37) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-02-05 18:28:39 * DTC Client socket (37) | Initiating close of socket by core. | 2018-02-05 18:28:39 DTC Client socket (37) | Closed. | 2018-02-05 18:28:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 18:28:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 18:28:39 Rithmic Trading | Disconnected. | 2018-02-05 18:28:39 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 18:28:39 Rithmic Trading | Port for executable: 52284 | 2018-02-05 18:28:41 Listening socket (712). Port 52284 | Closed. | 2018-02-05 18:28:41 Rithmic Trading | Starting server: C:\SierraChart3\Rim\DTCBridge.exe | 2018-02-05 18:28:41 Rithmic Trading | Bridge process is not running! | 2018-02-05 18:28:43 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52284 | 2018-02-05 18:28:43 DTC Client socket (38) | Creating socket. | 2018-02-05 18:28:43 DTC Client socket (38) | Connecting to IP: 127.0.0.1. | 2018-02-05 18:28:43 DTC Client socket (38) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-02-05 18:28:44 * DTC Client socket (38) | Initiating close of socket by core. | 2018-02-05 18:28:44 DTC Client socket (38) | Closed. | 2018-02-05 18:28:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-05 18:28:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 18:28:44 Rithmic Trading | Disconnected. | 2018-02-05 18:28:44 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-05 18:28:44 Rithmic Trading | Port for executable: 52286 | 2018-02-05 18:28:46 Listening socket (488). Port 52286 | Closed. | 2018-02-05 18:28:46 Rithmic Trading | Starting server: C:\SierraChart3\Rim\DTCBridge.exe | 2018-02-05 18:28:46 Rithmic Trading | Bridge process is not running! | 2018-02-05 18:28:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 52286 | 2018-02-05 18:28:48 DTC Client socket (39) | Creating socket. | 2018-02-05 18:28:48 DTC Client socket (39) | Connecting to IP: 127.0.0.1. | 2018-02-05 18:28:48 File >> Disconnect selected. | 2018-02-05 18:28:49 DTC Client socket (39) | Initiating close of socket by core. | 2018-02-05 18:28:49 DTC Client socket (39) | Closed. | 2018-02-05 18:28:49 Rithmic Trading | Disconnected. | 2018-02-05 18:28:49 |
[2018-02-05 18:47:48] |
Are you running Windows Vista or server 2008? Rithmic requires that you have Windows 7 or Server 2008 r2 or higher. This is a requirement from Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-05 18:48:15
