Date/Time: Sat, 18 Jan 2025 07:49:43 +0000
Combine alert on chart drawing with additional criteria?
View Count: 626
[2018-02-05 12:48:57] |
User961161 - Posts: 11 |
I use alerts on chart drawing and have set them up directly with the context menu on each drawing. Now I like to add additional criteria. I try to use the simple alert function and I saw the user manual on chart drawing references: Study/Chart Alerts And Scanning: Referencing Chart Drawings But it only states how to reference the anchor of a chart drawing, but is it possible to address also the whole line? e.g. the last price crossing drawing? thx & regards |
[2018-02-05 18:59:44] |
No it is not.
