Date/Time: Sat, 18 Jan 2025 07:51:46 +0000
Triggered Limit order - attatched order support
View Count: 826
[2018-02-05 02:40:31] |
User353585 - Posts: 66 |
Hello, I'm glad that you added the triggered limit order. What I'm currently looking for is the ability to use it as a part of my attached order. I often exit my trade using triggered limit order, while my hard stop still being in place. for example, say I have a long position at current price of 1150 with my hard sell stop at 1050. But I may want to exit the trade even before that if it touches 1100. So then I would set my triggered limit sell 1100/1125 so I can possibly exit at better price before it hits my hard stop. (1125 instead of 1050 if it gets filled) So what I want to see is the ability to combine them with target as an OCO order. currently I have to manually cancel the other orders if one of them gets filled. Will this be supported in future? Date Time Of Last Edit: 2018-02-05 02:46:07
[2018-02-05 10:16:14] |
Yes we can see about adding this. We will do that.
[2018-02-06 23:20:01] |
As we are implementing this, we realize this is a strange concept but we think we can figure it out. Since it is a limit order being used as a stop.
[2018-02-07 02:59:11] |
Thank you for the effort! I think it can also be considered as target. either way seems fine to me.
[2018-02-07 04:03:09] |
This has been released but only very briefly tested. It is in the latest prerelease. For an Attached Order it is considered a Stop type. Only use it in Trade Simulation Mode until you are comfortable it is working properly for you.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-07 04:03:29
