Date/Time: Mon, 25 Nov 2024 20:30:15 +0000
group detached charts under one logical window
View Count: 994
[2018-02-04 05:15:10]
User144295 - Posts: 70
Hi Sierra Team,
I use OBS project to record trading sessions from 2 LCD monitors. When I choose monitor 1, I can easily identify window as per header Sierra Chart 1625 NQ.cht etc.
But when I do the same for monitor 2 it is bit tricky because those charts are detached from the main panel. So I have to configure this for each window.
Is there any way how can I group all small charts on monitor 2 under one logical window as well?
Thank you
[2018-02-04 13:33:05]
The only way is to use another instance of Sierra Chart. Refer to:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
Date Time Of Last Edit: 2018-02-04 13:33:29
[2024-02-01 02:20:39]
mbarbhaya - Posts: 37
Dear support ,
Referring to the same request as seen in 2018,
Please help us add this feature where we can group two detached charts to form 1 chart.
This is one common feature in ToS, Quantower & MotiveWave ,
that helps a lot to group charts based on different targeted setups .
Thank you
Manish Barbhaya
