Date/Time: Sun, 24 Nov 2024 03:57:10 +0000
SCDLL beyong line 45 => " is missing the SCDLLName line. Refer to ACSIL documentation"
View Count: 1499
[2013-09-25 11:30:35]
wwwingman - Posts: 185
I have a SCDLLName in a tool I am building.
When it is in the begining of the file, compiler works.
When it is beyong line 45 it compiler gives an error : ".. is missing the SCDLLName line. Refer to ACSIL documentation".
This is bothering me because I like to put big comments at the beginning of the file (description, licence etc..).
Am I doing something wrong ?
W.
[2013-09-25 11:33:47]
This is true, just keep it at the top of the file. We do not see why that should be a problem. When looking for the SCDLLName line, we only search something like the first 1000 bytes or so of the file.
[2013-09-25 12:24:38]
Hi, thank you for the quick answer.
Indeed this is not a real problem.
My SCDLLName is built using some #define with names, version etc... below the description+licence header.
Anyway, I found a way around by putting a "//SCDLLName" on the top of the file. Silly, ugly, but it works.
W.
