Date/Time: Sat, 18 Jan 2025 07:36:19 +0000
Chart tabs layout
View Count: 2121
[2018-02-04 03:42:00] |
User264760 - Posts: 6 |
Is the layout of the chart tabs in a chartbook customizable or is there a way to see the charts in a list instead? Thanks. |
[2018-02-04 04:10:09] |
Xfanman1 - Posts: 320 |
You can click and drag the chart tabs in whatever order you want. Scott |
[2018-02-04 04:20:51] |
Not sure we understand the question. Here is the relevant documentation for Tabs: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#WindowAndChartbookTabs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-05 07:38:07] |
Thanks, the link helped. Here's my question rephrased: I wanted to know if there was a way to organize the MDI tabs in another fashion, like having more than one row of them. The objective for me would have been to be able to see all the tabs at once instead of having to scroll left/right when I have something like 30+ MDI tabs in a chartbook.
[2018-02-05 09:04:47] |
No, there is just one row but you can see all of the chart Windows through the CW menu at the top. But of course you have to click on that menu item to get the list.
