Date/Time: Sat, 18 Jan 2025 08:02:16 +0000
Increase maximum bars per chart
View Count: 1438
[2018-02-03 23:14:29] |
User826779 - Posts: 6 |
Hello, I would like to look at more data to review oscillators. Is there a way to increase the number of bars a chart will display? It seems there is a maximum of around ~1,200 bars. 4.5 years of daily bars or 2.5 months of hourly bars. Being able to look at the hourly oscillator for a year at a time would be great. Thanks |
[2018-02-03 23:23:36] |
There is no limit in this way. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-03 23:58:18] |
Correct, I can download more hourly data, but I can't display it all. My chart file currently has hourly data from Feb 2, 2018 back to Nov. 30, 2010. However, I can only zoom out far enough to see about 2.5 months of hourly data, Feb 2, 2018 to Nov. 22, 2017. Or I can scroll far left and see Nov. 30, 2010 to Feb. 22, 2011. Hope this helps. |
[2018-02-05 06:03:39] |
OK we understand. The only thing you can do in this case is to increase the time frame per bar: Changing Chart Bars Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
