Date/Time: Sat, 18 Jan 2025 07:50:50 +0000
Automated trading question
View Count: 826
[2018-02-03 22:37:43] |
bala - Posts: 74 |
I am planning to use automated trading. I plan to use "SupportReversals". At the end of the day I want to execute either Buy Exit or Sell Exit depending on the position. Question: Can I execute the exits I want eventhough SupportReversals is set to true or Do I have to set SupportReversals to False before executing an exit (buy or sell) |
[2018-02-04 16:48:15] |
Can I execute the exits I want eventhough SupportReversals is set to true Automated Trading Management: SupportReversals Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
