Date/Time: Sat, 18 Jan 2025 08:06:59 +0000
User Question
View Count: 726
[2018-02-03 19:29:33] |
Sierra Chart - Max - Posts: 5779 |
I'm interested in your software and I have a question can you also download the data from the past with the software and then edit it in an Exel table? As an example the last 500 days? Yes, you can download historical data. And yes, it is possible to export it to an Excel compatible format. Edit it, and then import it back. Exporting and Importing Intraday Data Files Text/CSV Data Format Sierra Chart Support |
