Date/Time: Sat, 18 Jan 2025 07:52:43 +0000
USDX Intraday Data
View Count: 852
[2018-02-03 11:50:31] |
User34124 - Posts: 279 |
Only goes back to 2016?
[2018-02-03 21:14:26] |
Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-04 22:29:14] |
Well if you do that it just starts from 22nd Sep 2016.... this is for USDX remember.. please check it.
[2018-02-05 00:10:49] |
The problem is you did not follow the instructions. The instructions are very clear. Follow them again step-by-step and make sure you read them clearly. Do not make any assumptions or skip a step. There is no problem here. Nevertheless, we did check both servers and accessed data back earlier than mentioned as seen below. There is even data back even further. HD Request # 3 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc | 2018-02-04 19:07:16
HD Request # 3 | Download start date-time: 2015-05-11 20:07:16.000 | 2018-02-04 19:07:16 HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2018-02-04 19:07:16 Socket (11) | Creating socket. | 2018-02-04 19:07:16 Socket (11) | Receive buffer size: 262144 | 2018-02-04 19:07:16 Socket (11) | Send buffer size: 0 | 2018-02-04 19:07:16 Socket (11) | Connecting to IP: 65.182.172.42. | 2018-02-04 19:07:16 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-02-04 19:07:16 HD Request # 3 | Sending historical data logon request message. | 2018-02-04 19:07:16 USDX [M] 1 Min #1 | Reloading chart. | 2018-02-04 19:07:16 HD Request # 3 | Requesting Intraday data. Start date-time: 2015-05-11 20:07:16. Record interval: 10. Symbol: USDX | 2018-02-04 19:07:16 HD Request # 3 | Decompressing data. | 2018-02-04 19:07:16 + Finished LoadSingleIntradayFile | 2018-02-04 19:07:16 Removed asynchronous window - Handle: 61343f8. Object pointer: 639c680 | 2018-02-04 19:07:16 HD Request # 3 | Receiving Intraday data for USDX starting at 2015-05-11 20:07:16 | 2018-02-04 19:07:17 HD Request # 3 | Timestamp of first Intraday data file record written: 2015-05-11 20:07:16 | 2018-02-04 19:07:17 Socket (11) | Maximum receive buffer size during socket life: 3337956 | 2018-02-04 19:08:02 Socket (11) | Initiating close of socket by core. | 2018-02-04 19:08:02 Socket (11) | Shutdown started. Waiting for graceful close. | 2018-02-04 19:08:02 Historical data download thread signaled to stop. | 2018-02-04 19:08:02 HD Request # 3 | Received 6103559 records from 2015-05-11 20:07:16 to 2018-02-04 19:07:50 (2.7 years) and wrote 6103557 records for USDX | 2018-02-04 19:08:02 HD Request # 3 | Completion time: 45s | 2018-02-04 19:08:02 Socket (11) | Socket gracefully closed by remote side. | 2018-02-04 19:08:02 HD Request # 3 | Intraday data download complete for USDX. Unique request ID: 2 | 2018-02-04 19:08:02 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-05 02:59:20
