Date/Time: Sat, 18 Jan 2025 08:03:20 +0000
Demo account
View Count: 1096
[2018-02-03 03:48:24] |
Monserrate G - Posts: 27 |
I have a live account I am trading with Global Futures on Sierra Charts. I want to do a tryout with OneupTrader. For this I will need a demo account that will last 30 days. How do I proceed to set this up? Thank you.
Date Time Of Last Edit: 2018-02-03 05:50:31
[2018-02-03 05:50:12] |
You just use your same Sierra Chart account. You do not need a separate one at all. Just install another copy of Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
