Date/Time: Sun, 24 Nov 2024 04:11:25 +0000
version 1028
View Count: 1566
[2013-09-25 04:07:24] |
fireworks11 - Posts: 63 |
After upgrading to version 1028 I recognized that I can't change the width of my time lines anymore. It stays at "1". Also, the draw type "dot" now looks like "dash". Please check. Thanks!
[2013-09-25 04:22:00] |
We will correct the problem with the line width with the Time Line study. We did not make any changes to the line style when drawing lines. Are you referring to the Time Line study in regards to the line style? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-25 15:37:10] |
Yes, I referred to the Time Line Study. I looked again at the "dot" style. It is indeed different from the "dash" style but it in version 1028 different than in version 1026. More important is the width though.
[2013-09-26 04:12:53] |
The linewidth can now be set with the Time Line study. Update Sierra Chart by selecting Help >> Download Prerelease. Due to how the timeline is now drawn, it is possible the line appearance will be different but this is not something we can control due to the improvement. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
