Date/Time: Sat, 18 Jan 2025 07:44:37 +0000
Gain capital is who Stage 5 clears thru so should I be able to get real time data thru ...
View Count: 1108
[2018-02-02 21:33:32] |
sjk - Posts: 43 |
I put in my username and password but it is not connecting
[2018-02-02 22:09:22] |
Here is the Gain Capital Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#SetupInstructions For connection problems refer to: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-03 14:19:47] |
sjk - Posts: 43 |
Thank you. I guess I should ask since I have brokerages at both, Interactive Brokers and Gain Cap. Which would you recommend?
