Date/Time: Sat, 18 Jan 2025 07:47:58 +0000
Upgrading an older version
View Count: 673
[2018-02-02 17:47:04] |
User704990 - Posts: 18 |
Can you please provide a link for the needed steps to upgrade an older version of sierra that's using notepad+ for acsil development to the current standard. (is it possible to still use the watcom compiler and notepad+ in newer versions?) Can I assume that all older dll's will need to be recompiled under the new version? Date Time Of Last Edit: 2018-02-02 17:53:09
[2018-02-02 18:26:34] |
Here are the instructions: Software Download: Fast Update (is it possible to still use the watcom compiler and notepad+ in newer versions?) Not the Watcom compiler. There is a new Remote Build feature that is much easier to use.Notepad ++ still supported. Can I assume that all older dll's will need to be recompiled under the new version? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-02 18:26:47
