Date/Time: Sat, 18 Jan 2025 08:02:29 +0000
Grid adjusted to the H/L of the tick on Chart DOM
View Count: 830
[2018-02-02 13:03:05] |
ticinotrader - Posts: 397 |
When the horizontal grid is extended to the Chart DOM, the horizontal lines of the grid run in the 'middle' of the ticks and intersect each price. This is different from how the grid in Trade DOM windows works. http://www.sierrachart.com/image.php?Image=1517576123982.png Is it possible to make this setting adjustable (draw the grid on H/L of ticks instead of the 50% of the tick)? Also, this can affect how drawing tools are displayed, because they are always snapped to the middle of the tick and not the Highest High or Lowest Low of the bar. Thank you! Date Time Of Last Edit: 2018-02-03 00:07:46
[2018-02-05 05:40:29] |
We are looking into this.
[2018-02-05 05:55:25] |
This is solved.
