Date/Time: Sun, 19 Jan 2025 15:21:46 +0000
Extending Crossover line until future intersection
View Count: 1624
[2018-02-02 13:02:16] |
User942837 - Posts: 108 |
Hi, is it possible to extend crossover price until future intersection please? thanks |
[2018-02-02 17:20:17] |
If you are referring to a particular study, which one?
[2018-02-02 17:38:28] |
Moving average crossover but ideally I'm trying to find a study where I could input a crossover study with other inputs from other studies not just moving averages. But the main question is, if there's a way to extend the crossover price until future intersections Date Time Of Last Edit: 2018-02-02 17:40:06
[2018-02-02 22:13:56] |
Yes, there is but it requires custom programming. It can be done with this function: sc.AddLineUntilFutureIntersection() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
