Date/Time: Sat, 18 Jan 2025 07:41:22 +0000
Horizontal line is not snapping to high/low of bar
View Count: 1995
[2018-02-02 12:19:29]
ita31 - Posts: 7
Hi
How do I fix drawing tool like horizontal line/ray not snapping at high/low of bar? I have disabled/enabled Adjust Tool Values to Tick Size and still does not correct it. I am using 8 range and 9 range charts. Any help is appreciated
thanks
[2018-02-02 12:48:02]
ita31 - Posts: 7
examples
Snapping sensitivity is set to HIGH
bar high/low sticks outside of the horizontal line/ray in range bars. Everything works fine in minute timeframes higher than 5minutes
15min timeframe
https://i.imgur.com/fdzitkY.png
8R
https://i.imgur.com/tFyZXeS.png
9R
https://i.imgur.com/iYybz81.png
Date Time Of Last Edit: 2018-02-02 12:48:49
[2018-02-02 21:58:04]
We did not look at the screenshots because they were not provided using the documented method:
For the behavior that you see and the solution, refer to:
Chart Drawing Tools: Automatic Snapping of Chart Drawing Ends to Open, High, Low or Close Bar Values
