Date/Time: Sat, 18 Jan 2025 07:49:26 +0000
[User Discussion] - Numeric Information Graph Draw Type Questions
View Count: 583
[2018-02-02 11:56:59]
LenderDevTest - Posts: 15
Hi, have a few questions about Numeric Information Graph Draw Type.
I use only one line in Numeric Information Graph Draw Type and the Graph region by default is too high for one line.
Is there a way to set Graph region height in pixels or to enable "auto size" that depends on count lines in Numeric Information Graph region?
Because it wants to resize chart region for one line Numeric Information Graph region by hands each time user applied the indicator. It's uncomfortable.
Another question is it possible to rotate numbers in columns to make it vertical?
When we scaling the chart the big values in columns start hiding. If we can show values in vertical(rotate 90) then the values in columns start hiding later and it won't depend on the count of digits in the values.
